Compare Lsi9 and LsiFx?
I would like to know your opinion or comparison between the speakers of the two models above for music? Are the LsiFx good for SACD? Thanks.
Post edited by haimoc on
From what I've read from users, the LSiFX do well in both localized and diffuse audio performance. A lot of it may depend on where they will be placed in relation to your listening position. If they are directly to the side, then the recommended setting is di-pole, in which the opposing drivers are out of phase, creating a diffused and spread out sound, harder to localize and hence counteracting their close [rpximity. When they speakers are placed behind the listening position, the recommended setting is bi-pole, in which the sound is still spread out, but not as diffuse as the di-pole setting. If you do go with the LSiFX, I think a good place to put them would be behind you listening position and set for bi-po9le, thus taking advantage of both direct and diffuse qualities.
the only thing is that the LSiFX's are huge, maybe bigger in overall dimensions than the LSi9's. So hopefully you have enough wall space and support.Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner -
If you think the LSiFX's are huge, check out the dimensions on the fx1000s.
Brian Knauss
ex-Electrical Engineer for Polk -
I'm also wondering if the FX will sound good with multi channel music. The large size has been mentioned. Are stands made that fit the FX?
