Inside of AQ.Niagara 5000
So I have been curious (even though there are pics online) to take a peek inside the Audioquest Niagara 5000. So all I needed was a push from @JayCee
Here they are:
    txcoastal1 Posts: 13,518
    Cool pics
    I guess the big question about the pics after following the circuits, and maybe someone much more intelligent than I, is whats in the sealed tube to the right where the HOT filters through
  • joecoulson
    joecoulson Posts: 4,943
    That’s definitely a question for someone who is above my pay grade.
    VR3 Posts: 29,521
    Could perhaps be harnessing the power of the bazooka tube to draw out the um, lower mid bass.
    Nice and clean guts, good stuff
    pitdogg2 Posts: 27,207
    Hexafluoriethylene metabolic gas notice the silicone.
    Could be an RTV
  • joecoulson
    So it is for Transient Power Correction:
    Our correction circuit bolsters and stabilizes the power supply of any power amplifier by providing a buffer and an instant current reservoir of up to 80 amps peak (20mS).
    F1nut Posts: 51,927
    edited June 2019
    I see lots of relays and commonly used baluns, which are good devices. I like how they have routed the wires, shows attention to detail.
    Sounds like a bank of capacitors. Well not any amp, my he-man amp is capable of 160 amp peaks, which is why it's plugged into the wall.
    Which amp Jesse?
    F1nut Posts: 51,927
    MF kW500
    I always wanted a pair of those 700/750 which ever those monos were back in the day. They were monsters from what I remember.
    Very nice amp by the way.
  • delkal
    delkal Posts: 764
    edited June 2019
    I am very disappointed the power outlets are all connected by just sicking a wire into the little spring loaded holes in the back. If you ever removed a wire from a connection like that you will see it has very little contact area. Just the edge of a thin copper spring digging into the side of the wire. I know it would be more labor to secure them correctly using the screws but at this price level it should be done right.
    I always preferred wrapping the wire around one of the screws and cranking it down tight. Has to be better. When I replaced my audio receptacle with a hospital grade one I saw all of the outlets in my house were wired by just sticking the wire into a very cheap plugs. After attaching the hospital receptacle using the screws I reconnected every other receptacle on the line by using the screws. Not sure if it made a difference but knowing the connections are secure lets me sleep better at night.
  • kharp1
    kharp1 Posts: 3,453
    They're probably not the shove in compression type connections. The screw still compresses a piece of metal against the wire.
    F1nut Posts: 51,927
    kharp1 wrote: »
    That's correct. IMO even better and certainly easier than trying to wrap large gauge wire around the screw.
    Clipdat Posts: 13,100
    I find it interesting that the internal wiring is made by Southwire. https://www.southwire.com/
    F1nut Posts: 51,927
    Looks like 12 gauge wire. Are the outlets 20 amp?
    The 4 on the left designated high current are:
  • kharp1
    kharp1 Posts: 3,453
    edited June 2019
    kharp1 wrote: »
    I agree, unless tinned properly the strands of wire will compress unevenly. Stray strands will often float loosely from underneath the screw, and, will cause uneven compression across the width of the wire. You'd be better off using a spade connector instead of looping the wire around the screw.
  • mikeyb128
    mikeyb128 Posts: 2,885
    edited June 2019
    Certainly doesn’t look like shove in type. If you’ve ever owned a quality audiophile outlet, then you already know the answer.
    2 channel:
    Theater:
    Pretty sure those stab in Chinese handcuff like outlets/switches have been out of the market for years. It's been decades since I've seen any new.
  • joecoulson
    Especially in a $4k conditioner.
  • verb
    verb Posts: 10,176
    Thanks for popping the hood Joe! Very interesting. Does look like a quality build.
    This guy's got me intrigued. Ferroelectric Chamber, akin to the Shunyata?
  • motorstereo
    motorstereo Posts: 2,359
    I have a similar unit in my Furman pc. I've read that it's a large storage capacitor that's similar to the starting capacitor on the top of large electric motors. It provides short term instantaneous current for high current amps.
  • delkal
    delkal Posts: 764
    edited June 2019
    mikeyb128 wrote: »
    That closeup picture clears things up. The connection is OK. The other pictures did have me wondering.
    So I was mistaken........Nice dig but why do you assume I never owned a quality audiophile outlet? The Hubbell hospital grade receptacle I used did not have the option to connect like on the power conditioner. Or is this receptacle considered hack and not audiophile?
    So maybe I am ignorant. How much do you have to pay to get an audiophile outlet? And are you sure they all have this alternate wiring option?
  • mikeyb128
    delkal wrote: »
    mikeyb128 wrote: »
    I didn’t assume anything. And I believe my Leviton hospital grade outlets that I still use on two of the 3 dedicated lines to my gear hook up the same way. My furutech outlet which is gold plated was around 60 bucks. Expensive but not outrageous.
    2 channel:
    Theater:
  • kharp1
    kharp1 Posts: 3,453
    They may very well be stab in type, but, I would seriously doubt that in such a quality piece. I haven't seen those type receptacles in a while. Will occasionally run across them doing rework, but, I never see them come in to the plant or in stores. Though I will admit I don't browse the store shelves much these days.
  • delkal
    delkal Posts: 764
    I was mistaken in my first post that it was a spring loaded push in connection and I later admitted it. I never saw a receptacle with that kind of connection and it had me scratching my head. There was never a question the power conditioner was quality and it didn't make sense! Thanks to the people who explained it to me.
    I only replaced a few outlets with Hubbell hospital grade receptacles and they did not have that connection option. So while I have only dipped my toes into "semi-audiophile" plugs that connection was not obvious to me. So I guess I didn't know the answer.
    F1nut Posts: 51,927
    It's ok.
  • mikeyb128
    Those outlets have a death grip that ripped a ground lug off a 70$ furutech plug. So watch out for that hahaha
    2 channel:
    Theater:
