Youse guyses is wise in the ways of automotive care products; what's a good glass cleaning product?
mhardy6647
Looking for recommendations/suggestions for a good, non-streaking glass cleaner (and or methodology) for auto glass. Specifically, for the inside surface.
I know from my past life in the lab that 95% ethanol will leave plate glass very, very clean (back in the olden days, we used to make our own polyacrylamide gels for protein electrophoresis, cast between plates of very clean glass). I'd prefer a "commercial" solution (although I do - still - keep some 190 proof EtOH around for solvent use).
Thanks!
Thanks!
+1 on Invisible Glass. I find the Aerosol version better then spray bottle.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
Do you think your title is long enough? I second/third the Invisible Glass. Works great.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Thanks!
With a name like Stoner, it has to be good...
Best advice I can give, don't clean any glass that's been heated in direct sun. That streak-free claim will go... wait for it... out the window.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I think a quality waffle-pattern micro-fiber towel is more important than the solvent/cleaner. Plain water will work fine for a streak-free finish IF the glass is already clean."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
https://www.amazon.com/Sprayway-Glass-Cleaner-6-Cans/dp/B000AP585M/ref=mp_s_a_1_11?keywords=sprayway+glass+cleaner&qid=1560334059&s=gateway&sprefix=sprayway&sr=8-11
Terrible for the environment and tested on baby monkeys.
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
This is excellent; thanks,folks!
I note wryly that the Vanilla censor battered @Mikey081057's amazon link. Now I have to guess what the **** was (I think I can suss it out...). EDIT: interestingly, Amazon parses the link correctly(?!), despite the censorship (the address bar still shows the asterisks, but the page loads). Technology...
@mrbiron, do they have one that contains whale oil, ambergris, or elephant ivory?
EDIT: Contains perfume-grade alcohol. Is that better or worse than, e.g., wino-grade alcohol?
Haven’t found much difference between regular old Windex and Stoner myself. Even the generic stuff will get the job done. As long as it’s used sprayed onto a microfiber cloth rather than the windows and done on glass that’s out of the sun. I only clean the inside of glass once a year though! Paper towels are not good as they are made of wood product chippings and glue.
My luck with windex is (heh-heh-heh) spotty.
I've usually used microfiber just as a final 'polish'; haven't tried using it for application.
I always clean glass in the garage. Heck, I try hard not to clean the house windows* when the sun is shining on 'em.
____________
* Not that we clean 'em very often... they need it now, in fact. Dang "six over six" windows are a pain to clean. I even used to have an itty-bitty squeegee to use on 'em, but the rubber rotted & I've yet to find another one of the right size.
Invisible glass is also tint safe.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
It's not a spray, but Zaino glass polish is a compound you apply and buff until it dissapears.... Take a little longer but the glass becomes liquid like when done.
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If ya have some automotive polish not wax, that can help with streaks on glass. I put a very light application on mine and it works wonders for me.
Rain-x makes a glass cleaner and treatment for your windshield which down here where it rains so hard that wipers are useless... works great don't even need wipers. Only for the exterior.
I always use rain-X after cleaning that is the bomb and agree water shoots off the glass. I use the invisible glass cleaner for me I found it works best and yes I spray it on a clean microfiber cloth and go back over with a dry micro fiber cloth. I dislike any glass cleaners that foam for me they are the worst at streaking.
You shouldn't use Windex or any ammonia based glass cleaners tinted film.My New Year's resolution is 3840 × 2160
I second the spray way aerosol cleaner.
Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
Invisible user here too plus microfiber cloth
The best advice I have found online, is to use a new microfiber cloth to wipe the inside glass first before you use any cleaner. Gets the film off of it. Then use a different microfiber cloth with whatever spray you use. And, as stated above, do it when the window is out of the sun.
mhardy6647 wrote: »(although I do - still - keep some 190 proof EtOH around for solvent use).
yea that explains the slurred typing.... Solvent use now that is FUN E
I use Sprayway glass cleaner, can be found at Walmart. Then follow that with a claying using the Griot's Garage glass clay with Speedshine as a lube.
Duuuuude -- I was at Home Despot this morning, and they had some of that Stoner stuff. Like, wow, man...
I'm gonna crank up some Dead and give it a try later.
Maybe I'll turn on a black light, too*.
Whoa.
______________
* unless y'all think that'll increase the likelihood of streaks on the glass, man...
In seriousness, thanks to all for the advice and tips.
We don't window tint here. Remember we live in near total darkness six months out of the year up here
mhardy6647 wrote: »Duuuuude -- I was at Home Despot this morning, and they had some of that Stoner stuff. Like, wow, man...
Whoa.
______________
If Russ cleans your glass, guaranteed to have streaks -
Gin and newspaper does a great job
Water, white vinegar and news papers.
I know that 'newsprint' is a good matrix for cleaning glass, specifically for removing grease. I know several folks who swear by it for eyeglasses, although it seems a little coarse to me for that.
So...
Is actual newspaper (with whatever sort of vegetable-based inks they use nowadays) still good for cleaning glass?
I ended up doing outside chores today & haven't - yet - gone Stoner.
mhardy6647 wrote: »I know that 'newsprint' is a good matrix for cleaning glass, specifically for removing grease. I know several folks who swear by it for eyeglasses, although it seems a little coarse to me for that.
So...
Yeah, newspapers still work fine and it's better than reading them. -
Mark, use a good quality Clay bar to remove embedded contaminants from the porous glass, then you can use the Invisible Glass "glass cleaner."Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
