Marble Slab?
Whadyasay
Does anyone know a good place to order a custom-cut marble slab to be placed either underneath or on top of a subwoofer enclosure?
Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
Post edited by Whadyasay on
Where do you live?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I would go with Granite and you can get it at most custom counter places or Home Depot.
Thanks for the replies, guys. I live in NYC, and I just got back from Home Depot. They didn't really have a marble selection except for floor tiles, but granite seems like a good choice for placing underneath. I did see a thick solid-wooden chopping board that would be a perfect fit either above or below. The wood is almost 2.5" thick and the piece is quite heavy. Asthetically, it would go nicely on top of the sub, to give it a nicer end-table motif (I rest a small plant on top of my sub), so I might just go with that.Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
How about some Home Depot marble contact paper with a double layer of MDF. Total cost about $15.Samsung PN60E6500
Denon AVR-E300
Mains: LSI9s
Center: LSIC
Surrounds: LSIFX
Subs: Two Atlas 12's with Rythmik 350W amps in ported 95L box.
Power: Monster 2600 power conditioner -
Naah...I'm goin' with the chopping board...that way I can eat cheese and crackers off of it when watching a movie.Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
marble slab......mmmmmmm.......Birthday Cake is my favorite, with sweet cream a close second...
The most cost effective method is to get a scrap piece left over from cutting a kitchen sink hole.
Cabinet makers regularly have these leftovers.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
The cheapest method is to spend about $3 on an 18" x 18" concrete paver in the gardening section of Home Depot or Lowes. Pay another $3 for some spray paint.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Hey guys, sorry for my ignorance. But could you fill me in on the benefit of utilizing a granite slab underneath and/or on top of you sub (and try to quantify such benefit)?
I have a PSW450, and just contemplating the granite slab after reading this post.
Thanks! -
Quantify? No need to if you use the thing God gave ya between your ears.
With wooden floors, it can be a great benefit. The mass of the slab dampens the vibrations of the sub enclosure, thus keeping them from being transferred into the flooring. If the subs vibrations are transferred into the flooring, the flooring becomes a second speaker. With a concrete floor (slab), it would be of no benefit. Think of it as a subwoofer condom. It keeps the sub's "vibrations" from "penetrating" the flooring. Go BIG or go home! -
Thanks for the reply. I should've performed some searches first before asking my question, sorry
Wow, lots of threads on this topic.
Mostly I've read...
- helps to not disturb neighbors living below
- may help to reduce muddiness and boominess
- may be a greater improvement for down-firing subs
I don't necessarily have complaints about my sub now. I was only asking since I'm always looking for improvements (aren't we all)
So maybe I'll pick one up if I find a slab real cheap somewhere, otherwise I might not worry about it.
Thanks again! -
After someone suggested the leftover countertop granite pieces, I realized a gentleman that attends church with me does this for a living.
I talked with him this evening and he can get me pretty much any size I need for my house and some of the other HT projects that I'm working on, and all for next to nothing.
So, if anyone around Memphis needs a granite slab for thier sub, or tower speakers for that matter, just let me know.
Just for your info, the granite is about 1.25 inches thick and weighs approximately 22lbs/sq ft.Tschüss
Zach -
Okie - I have the same type of hookup and had/have granite out the arse. It's all in who you know.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I'm assuming a finding a quarry within a decent drive of you is out of the question. If not, a quarry would be a great place!Brian Knauss
ex-Electrical Engineer for Polk
