Normal idle temp for a B&K Reference 30?
CGTIII
CGTIII Posts: 1,243
For those with a B&K Reference 30, how warm is it at idle? With an ambient temperature of 76F sitting on a hard shelf with 1.5"+ clearance for both top and sides, the laser in my multimeter is showing up to 112.5F on the top. Is that normal?
(Yes, I know it has a computer running inside with passive cooling.)
There's no substantial heat from any device below it as of this measurement.
Boston - CR7, CR6s, CR4s.
​Thompson Adventures, Inc.
  • Emlyn
    Emlyn Posts: 4,787
    I recall seeing one in store years ago and almost bought one but didn't because they had a several week back order and it was expensive. Went with Rotel instead. I do remember that it ran quite warm, and was surprised by that. The manual should say how much clearance is recommended. The 1.5" on top may not be enough.
  • CGTIII
    CGTIII Posts: 1,243
    Manual says 3" top clearance. That's why I have two AC Infinity fans on it now.
    (Heat measurement above taken without fans running for an hour.)
    My question about how much heat others have.
  • CGTIII
    CGTIII Posts: 1,243
    edited June 2019
    I appreciate the input @Emyln.
