Best Carpet Cleaner
  • jflail2
    jflail2 Posts: 2,868
    treitz3 wrote: »
    http://www.whatsbestforum.com/showthread.php?6466-Steam-Cleaners
    Read the whole thread for an educated response to your inquiry based upon real user experience (mine).
    great write up Tom. Sounds like exactly what I need as I only have 1 room with carpet and then some area rugs on the hardwood floors.
  • jflail2
    And one additional thing I'd recommend for home cleaning are some brushes that attach to your drill. Here is a good example. Great for cleaning showers, a caked up frying pan, or anything else with a stubborn stain on it.
    audioluvr Posts: 5,915
    jflail2 wrote: »
    Don't use brushes ( especially rotary) on carpets with cut pile. It will destroy the twist built into them which is what makes them fluffy and springy.
