3.1tl build
VR3
Clarity csa
Jantzen Superes and inductors + c coil
Supra wiring and sda cable
Point to point with with terminal plates
Niceee! how do you like the CSA? where do you get the internal speakers?
Supra? Madisound is the USA distributor, great wire, imo
I like the csa, little warmer than the older series without sacrificing clarity and detail.
Thank you!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thank you!
Thanks, I will order a few feet to redo my speakers.
I have the same opinion in regards to the CSA, it really did wonders to my speakers to end. -
Oh man, those look fantastic bud.
Those are going to make the ol 3.1TL's sound much better...
A far cry from the old stock crossovers..
Yeah I remember THOSE old things.
Sold ‘em on eBay after I installed my new crossovers from @VR3
Looks like he’s done some updating since he did mine. -
Not to much, the csa series has just taken over the Esa where as before it was like 50/50.
But I do like to change things, hence version 3 audio 😜
Thanks guys!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
