AC iPurifier has anyone tried it"?
It's $100! You should order one and let us know what it does.
I ordered one today. Going to see if I can eliminate some of this DC noise coming from my house wiring.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
Yeah, got it a few days ago. No help. Sending it back tomorrowOnkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
@jayman_1975 can you descibe the noise and how it makes you feel?
jayman_1975 wrote: »I ordered one today. Going to see if I can eliminate some of this DC noise coming from my house wiring.
Don't you need something like this to combat DC on the AC? https://emotiva.com/collections/accessories/products/cmx-2 -
^^^^^^^^^^^^^^^^^^interesting unit.
IF the goal is removal of a DC offset from the AC mains... an isolation transformer (i.e., any transformer with inductively-coupled primary and secondary windings -- as opposed to an autoformer) will isolate any DC riding on the input from the output.
You can use any 1:1, isolating transformer of sufficient VA capacity to eliminate a DC offset on an AC line.
Something like this is handy for low-medium power requirements. I think I paid $30 for this at a radio fleamarket. Note that, besides providing isolation of the load from the AC mains, this doohickey also provides some limited, fixed adjustment of the output voltage (90 to 140 VAC, based on a nominal 120 VAC input) -- i.e., some of the functionality of a Variac, but with the added benefit of isolation. Variacs are variable autoformers, and as such do not isolate the load from the AC mains.
The isolated outlets are rated for up to 350 VA at 140 VAC (350 VA is equal to 350 watts
if the power factor of the load is 1).
mhardy6647 wrote: »IF the goal is removal of a DC offset from the AC mains... an isolation transformer (i.e., any transformer with inductively-coupled primary and secondary windings -- as opposed to an autoformer) will isolate any DC riding on the input from the output.
Come on now Doc....
lsi 9's -
Math give me hives, man.
The irony being that our daughter's an economist and our son's a mathematician. -
mhardy6647 wrote: »Math give me hives, man.
Love math!
And your rheostat! That brings back memories! Mark you got all the cool toys!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
ain't that cool?! Picked that up at some fleamarket or another. Pretty serious variable resistor; if I had two, I think they'd be excellent in a crossover network
afterburnt wrote: »@jayman_1975 can you descibe the noise and how it makes you feel?
My tv buzzes and so does my sub. I think the buzz in the sub is coming from the amp. It ticks me off.
Arcam CD37
Vandersteen V2W -
Isn’t that what the ipurifier is supposed to be doing?Onkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
I don't think so (?) I thought they were for noise.
https://ifi-audio.com/products/ac-purifier/
Yes, the blurb seems to support the notion that they are noise filters of some sort.
It draws from French military engineering. 'nuff said.
Better than French social engineering.
