POLK AUDIO Goodies and Other Stuff
dorokusai
dorokusai Posts: 25,576
I have some Polk stuff and other things that are FREE.
It’s a simple pencil and screwdriver thing.
There are 3 pairs, first come first served. I’ll cover mailing them.
I also have some dampers I picked up along the way.
The ridged foam, no idea where I got them. FREE.
The other hard rubber dampers are nice. I was told they’re used under
Air Conditioners/ HVAC to reduce vibration. I think WWaldecker gave a bunch of us at a Polkfest. FREE
PM me your shipping information. Easy.
  • dorokusai
    I also found some silicone tube dampers for 6DJ8 type. FREE.
    nooshinjohn Posts: 25,173
    The pencils and screwdrivers... were these actually used in Matt's lab coat?
  • dorokusai
    I have no idea.
  • Willow
    Willow Posts: 10,892
    Are the black and blue ones too dense to use under a tt?
  • dorokusai
    I wouldn’t use them on a TT. I’ve had great success using Bright Star Audio. Probably have 3-4 of their lineup. Lead filled and an air bladder design, great stuff.
    The Waldecker pads have been snapped up. Done.
    mhardy6647 Posts: 33,185
    For the record (heh... see what I did there?) some folks do use the "black and blue things" under turntables...
  • dorokusai
    I’m just saying that I wouldn’t, not that you couldn’t.
  • honestaquarian
    honestaquarian Posts: 3,186
    I'll take a pencil and screwdriver
    PM forthcoming
  • codycatalist
    codycatalist Posts: 2,662
    PM incoming on the silicone rings. I got some tubes they will fit that are a little microphonic, would like to see if this helps.
    Tony M Posts: 11,040
    B)
  • dromunds
    dromunds Posts: 9,993
    They are not just screwdrivers, notice the top. Very handy.
  • dromunds
    Maybe I should've just said notice the top, its very handy
  • dorokusai
    Honest - I got you for one. I’d like to spread around but thanks. 1 pencil n screwdriver gone, 2 left.
    d
  • vmaxer
    vmaxer Posts: 5,116
    Another pencil and screwdriver?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • dorokusai
    Yes. 2 more.
  • dromunds
    Jeez, I can’t resist a pencil and screwdriver.
  • dorokusai
    edited May 2019
    All the pencil/ screwdriver combos are accounted for TY.
    The blue/ black isolators are accounted for as well.
    The silicon tube condoms have been handled.
    All I have left for FREE at this point, is the yellow/ orange isolators. They’re not pretty. I guess but if you’d like to make your own opinion, in regards to isolation theory or idea...I think you’d be hard pressed and closed up to deny the word FREE. Good luck in all you do.
    edited May 2019
    Somebody could paint those isolators any color they prefer. ;) Black spray paint. :s
    Cool gifts you just passed on FOR FREE! B)
  • dorokusai
    Tony I’ve had so much dropped in my lap, over years. That no one cares about for a few of us nerds. It’s my obligation to pay it forward here. That’s what I do. Im not gonna say HEY take this amplifier 😀 but I’m sure you get it.
  • dorokusai
    Send me your mailing address and I’ll mail you a kick **** rare item. Not joking lol as I read that again. In regards to Polk nerdom? This is rare. My pleasure.
    d
  • dorokusai
    Im fairly certain you’re gonna have this and that’s what I’m talking about. Audio is a hobby that’s cool to hoard until you can’t find more boxes. I’m sure there’s more but I doubt it. Keep on keeping on.
    That's awesome Mark!!! B)
    I like RARE things. ;)B)
    I sent my address through PM.
    Thank you. ;)
  • dorokusai
    No problem.
  • Jstas
    Jstas Posts: 14,718
    edited May 2019
    But isn't your plinth made of, like, solid lead? They would be useful on that because of the weight. On something lighter, they'd be like blocks of wood.
    For something like a 90 pound SVS subwoofer, they would work great as the level of energy needed to vibrate something like that is what they were designed for.
    They aren't expensive, though, about $10-$15 a pair and you can probably get away with one pair and cut them down with saw. So if somebody wants them, this is what you are looking for:
    https://www.amazon.com/Diversitech-MP4-V-Anti-Vibration-Pack/dp/B00BVEMLR4/ref=pd_lpo_vtph_469_bs_img_1?_encoding=UTF8&psc=1&refRID=HJQ5HBGBZ0K3JYHTFRJ4
    They aren't the prettiest things in the world but they are effective. I used them under a 60 gallon air compressor in the shop to keep it from vibrating the floor around it.
    Expert Moron Extraordinaire
  • dorokusai
    Aside from one item, the vibration pads, shipped today. I need a small envelope for those. Let me know when you folks receive the goodies and thanks much.
  • codycatalist
    dorokusai wrote: »
    No thank YOU doro!
  • honestaquarian
    Got mine today in the mail.
    Thank you! o:)
  • dorokusai
    Sweet. Now you have my DNA. Hold off on the killing for a couple weeks.
  • dorokusai
    The silicon rings left...does anyone want these other feet? If not I’m just gonna throw them in the trash.
    dorokusai wrote: »
    I think they would be great between components for more breathing space and so easy to paint black. Maybe even replace some hard feet under a component with those.
    I would paint and use them sometime in the future but I want somebody else that could use them to chime in and get them. They look like great spacers.
