Zu Bok 9ft power cord
doctorcilantro
doctorcilantro Posts: 2,028
edited March 2019 in For Sale (FS) Classifieds
Ships from USA, here is a really nice Zu Bok power cord no longer in production. Really perfect for DACs, preamps, and digital transports. Pretty flexible cable, with custom terminations from Zu Audio. Asking $199 net total (retail at 450) shipped USPS.
cheers!
Bok AC mains power cables are designed as a universal needs, balanced high performance mains cable for use on all pro audio and home audio equipment. And though it looks small-ish in diameter, Bok is a very high conductance (#11 gauge high/#11 gauge low, #9 gauge Earth) design.
BOK SPECIFICATIONSZU AUDIO | 3350 S. 1500 W. | OGDEN, UTAH — U.S.A. [DESIGNED AND MADE BY US] WWW.ZUAUDIO.COMZU AUDIO BOK Mk.II [REV-A] AC MAINS POWER CABLE SPECIFICATIONS + INFORMATIONDesignDevice Under TestProductionDesignManufacturerVoltage RatingCurrent RatingDielectricCable Geometry Line Conductors Neutral ConductorsGround ConductorLine Conducting AreaNatural Conducting AreaGround Conducting AreaRs LsCable SheathBend RadiusCable DiameterRoHSStandards ComplianceManufacturers Country Of OriginLife ExpectancyWarranty & ServiceZu Bok AC mains power cable is designed as a universal needs, balanced high performance mains cable for use on all pro audio and home audio equipment.Zu Bok Mk.II [Rev-A] 6.6’ [2.0m][5266i Wattgate plug > 320i Wattgate IEC]2002–Current (Mk.I and Mk.II differed in termination only)high conductance, fl exible, low radiating, unfi ltered, power cableZu Audio600 volts20 amps (limited by connector specifi cation)PTFE/PE/PVC/air/CuZuB3™ Tefl on®/PE/MTW > 105 ̊C, copper + silver/copperTefl on®/PE/MTW > 105 ̊C, copper + silver/copperMTW/AWM 105 ̊C, copper + tin plated copper≈ 11 AWG [4.1mm2]≈ 11 AWG [4.1mm2]≈ AWG #9 (6.63 mm2).02 Ω (line).02 Ω (neutral).01 Ω (ground)6.2 uH (high/line) 6.2 uH (low/neutral) 5.9 uH (ground)Dacron monofi lament braid2” [51 mm].48” [12.2 mm]compliant
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • doctorcilantro
    Bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    Bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump dropped to $125
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    SOLD
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump - still for sale
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
