Zu Bok 9ft power cord
doctorcilantro
Ships from USA, here is a really nice Zu Bok power cord no longer in production. Really perfect for DACs, preamps, and digital transports. Pretty flexible cable, with custom terminations from Zu Audio. Asking $199 net total (retail at 450) shipped USPS.
cheers!
Bok AC mains power cables are designed as a universal needs, balanced high performance mains cable for use on all pro audio and home audio equipment. And though it looks small-ish in diameter, Bok is a very high conductance (#11 gauge high/#11 gauge low, #9 gauge Earth) design.
BOK SPECIFICATIONSZU AUDIO | 3350 S. 1500 W. | OGDEN, UTAH — U.S.A. [DESIGNED AND MADE BY US] WWW.ZUAUDIO.COMZU AUDIO BOK Mk.II [REV-A] AC MAINS POWER CABLE SPECIFICATIONS + INFORMATIONDesignDevice Under TestProductionDesignManufacturerVoltage RatingCurrent RatingDielectricCable Geometry Line Conductors Neutral ConductorsGround ConductorLine Conducting AreaNatural Conducting AreaGround Conducting AreaRs LsCable SheathBend RadiusCable DiameterRoHSStandards ComplianceManufacturers Country Of OriginLife ExpectancyWarranty & ServiceZu Bok AC mains power cable is designed as a universal needs, balanced high performance mains cable for use on all pro audio and home audio equipment.Zu Bok Mk.II [Rev-A] 6.6’ [2.0m][5266i Wattgate plug > 320i Wattgate IEC]2002–Current (Mk.I and Mk.II differed in termination only)high conductance, fl exible, low radiating, unfi ltered, power cableZu Audio600 volts20 amps (limited by connector specifi cation)PTFE/PE/PVC/air/CuZuB3™ Tefl on®/PE/MTW > 105 ̊C, copper + silver/copperTefl on®/PE/MTW > 105 ̊C, copper + silver/copperMTW/AWM 105 ̊C, copper + tin plated copper≈ 11 AWG [4.1mm2]≈ 11 AWG [4.1mm2]≈ AWG #9 (6.63 mm2).02 Ω (line).02 Ω (neutral).01 Ω (ground)6.2 uH (high/line) 6.2 uH (low/neutral) 5.9 uH (ground)Dacron monofi lament braid2” [51 mm].48” [12.2 mm]compliant
cheers!
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
BumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
BumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bump dropped to $125For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
SOLDFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bump - still for saleFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
