Isolation Pads to angle center channel
pawelmwo
pawelmwo Posts: 137
Hey everyone looking for feedback on the Auralex MoPAD-XL for the Polk 706c center channel. It is expensive but if it does the job will pick up a pair. They come with wedges that let you change the angle. I'm only wondering if it will work since the speaker is a bit curved.
https://www.amazon.com/Auralex-Acoustics-Acoustic-Isolation-Charcoal/dp/B00266HBSU/
