Isolation Pads to angle center channel
Hey everyone looking for feedback on the Auralex MoPAD-XL for the Polk 706c center channel. It is expensive but if it does the job will pick up a pair. They come with wedges that let you change the angle. I'm only wondering if it will work since the speaker is a bit curved.
https://www.amazon.com/Auralex-Acoustics-Acoustic-Isolation-Charcoal/dp/B00266HBSU/
https://www.amazon.com/dp/B07H1D66GT/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B07H1D66GT&pd_rd_w=QOxtv&pf_rd_p=46cdcfa7-b302-4268-b799-8f7d8cb5008b&pd_rd_wg=4hRfi&pf_rd_r=5K3C3EC8K34HNM8TJGZ8&pd_rd_r=42e86f66-70f8-11e9-b88a-83630affe59b This looks more cost effective. You don't get the cool logo badge but, you still get the job done, and, should cradle the 706 just fine either way you go.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
Mine is sitting on those litte blue vibration pads. Pretty cost effective solution.
Hockey pucks
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Damn I jumped the gun and ordered them. Might return and get these instead. -
Floor hockey....do kids still play floor hockey in gyms or on tennis courts?Mikey081057 wrote: »Hockey pucks
