D1000.1 - 2 speaker outputs question
Hi there - new to the forum! But alas, I can't find an answer to a burning question I have about my PA D100.1 amp.
If I have one SVC 4ohm subwoofer, and hook it up to the negative of one speaker output, and the positive of the other (so the outside two terminals), will this effectively parallel the 4ohm into 2ohm? Thereby generating 800w RMS output from the amp?
Thanks!!
Best Answer
Answers
  • PastorPastor Posts: 5
    Ahh right, thanks for the clarification! What about if I have two DVC subs at 4ohm, each wired separately into each speaker output? What impedence would the amp produce then?
    edited May 7
    According to the manual:
    "The Polk Audio PA D1000.1 amplifier offers two positive and two negative output terminals for ease of connecting the speakers to the amplifier . Since this is a mono amplifier, connections are wired in paralleled internally. The amplifier is stable to 1 Ohm."
    So just need to clarify the effect of this on the ohm's produced.
    Cheers :)
  • codycatalistcodycatalist Posts: 2,414
    edited May 7
    Pastor wrote: »
    Cheers :)
    Sure thing bud.
    Easier to explain via a picture than words.
    Basically you will daisy chain the positive to positive and negative to negative.
    With dual 4 ohm subs wired in parallel it will be a 1 ohm load to the amp.
    ***Be careful when putting that amp in 1 ohm, chances are it will get HOT and could go into thermal protection.
    Thanks Cody! Any chance you can decipher the wiring scheme for this Hertz HX300D?
    I have the wires going to the outside terminals as suggested for 2ohm parallel wiring, then straight into one pair of speaker outputs on the pad1000.1 amp. Not sure it’s correct though
    Ahhh no, just saw my mistake. Wires meant to jump from the inside positve to outside positive, then into amp? Same for negative?
    So currently I'm running at 8ohm?! haha
Howdy, Stranger!
