Why not try it?
Hi there!
I'm looking for a good couple of RCA cables to connect my Pioneer XDJ's to my Pioneer DJM-900NXS2 mixer. I read a lot about Mogami cables and their top quality but wasn't sure about picking between 2534 or 2964.
Keep in mind it's just to use at home, my dj gear never leaves my apartment and I wanna spend money on real cables that are worth it
Which would be a good cable with balance between high quality and interference shielding? I mean I want good cables for their build quality and sound quality but also I need some that won't damage my gear on the long run.
I'm thinking on spending maximum $50 per cable (since Mogamis are around 40).
Hope you can help me.
Thanks a million in advance! -
Hi there!
If you post a separate thread in the want to buy section, there is a good chance someone will have some good used cables for you to buy that will be better for about the same money. Waaay more bang for your buck with used cables...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
