Looking for 1 sl 2500 tweeter
Dan2019
Best Answers
Looking for sl 2500 tweeter
Thx -
Yes drop in fit.
Witch one ?
Thx
RD-0198 is a drop in replacement for the SL2500/3000 tweeters.
Call polk cs tell them you belong here for a small discount. They are 60.00ea. normally and 48.00ea for members of the forum. -
Ok thx for your advice I appreciate !! SL 2500 are very hard to find second hand !! Delivery fees cost almost the same as the tweeter !!
I might have one in the attic. I'll try to track it down.
Hi
Can I sell my monitor 12 2 series on this site ?
Thx
Sure you can, but unfortunately you're still about 90 posts shy from reaching the selling threshold. Keep on posting you'll be there in no time.
Answers
Buy a pair of RD-0198's from Polk they're leaps better.
Thx do they fit for monitor 12 2 series ?
Dan -
Yes, they are the factory replacements for the SL2500 and SL3000 tweeters.
Witch one ?
Thx -
What do you think about peerless tweeter
Apparently they fit in m-12
Thx -
Your crossover was not designed for the peerless tweeter.
Of course you can use whatever tweeter you want they're your speakers. -
HI everybody !! I have monitor 12-2 I checked the polarity twice on my system I am loosing bass when I am sitting in front but by the side the bass is perfect any idea what causes that ? Is there a position specific for the speaker ?
Thx for your responses
Dan -
Hi
Thx -
For sale monitor 12 2 series
Hi
Thx
Nope not legally until you have 100 posts.
You might have an air leak check all screws to see if tight. Push in and hold the passive watch midwoofers they should stay out and slowly recede in 3-5 seconds
