Sell me an amp for my SDA 2B's
jbail2011
I really wanted a Parasound 1500a but I can not get my hands on one. I have a B&K Pro 10 pre amp and a Velodyne ULD 15S7 sub (which may not work with this set up but I am restoring it anyway because it is beautiful!).
I need an amp and IC cables... Any suggestions?
And when can I add a profile picture?
Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i
Bluesound Node 2i
Best Answers
Welcome to CP!
If you're look'n to go big (or go home, as they say) . . . . I've got an Adcom GFA 5802
shipping won't be cheap at 48lbs + shipping material
I don't believe that is common ground yeah?
I have a GFA-545 mk1 on my 2Bs and it pushes them effortlessly. For what it's worth.
Answers
I have an Adcom GFA-545 that I'd let go.
Bluesound Node 2i -
You know, it's interesting I just spoke with Polk while ordering an ic cable and he agreed with you DaveHo. I have a Adcom 535 series 2. I'll try this first. I may get back to you on the 545. Thank youPolk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
Welcome to CP!
shipping won't be cheap at 48lbs + shipping materialAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I have recently acquired a Musical Fidelity 3.2 integrated amp.
It is a dual mono amp and is not a common ground amp. I have a Dreadnaught from the last group buy, and it solves the non common ground issue for the 2B's and some other SDA's.
My 2B's have never sounded better. I have heard things in song tracks that I have never heard previously and vocals are so much clearer and refined. I use JRiver and a PS Audio Nuwave DSD DAC."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Welcome to CP!
Holding out on me @GlennDog ?
And I believe you have the matching pre?
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Give me a buzz tomorrow if you’re interested ...AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
I swear I called musical fidelity and inquired about the a3.2 being common ground and they said it was. I used it with some 2Bs for a while and nothing caught fire. Maybe I was lucky?
