banana plugs on Atrium speakers
Hello,
My family has a remote cottage with a pair of Bose indoor/outdoor speakers that have been damaged by vandals. (If you get the speakers out, you are supposed to put them away, so stuff like this doesn't happen...).
I was considering replacing the Bose speakers with Polk Atrium 6 speakers.
The Atrium 6's get good reviews, I particularly noted that they get good marks for a friendly bracket design.
We use dual banana plugs to make plugging and unplugging as smooth as possible.
One reviewer noted that he was not able to use a banana plug on his Atrium 6.
I would appreciate any input I can get on this, as in my application, the banana plug is going to be close to a deal-breaker.
If banana plugs can not be inserted in the speakers, I suppose I can make very short 12 gauge jumpers with spades on the speaker end and female bananas other, but it goes against my grain to add an unnecessary connection in a signal path.
Best Regards,
Bil
  • verb
    verb Posts: 10,176
    edited April 2019
    Hey welcome to CP! Looks like they can accept bananas or spade terminals. May be a tight fit, depending on the orientation to the mounting bracket for sure. In that case, you should be able to use a angled spade to banana adapter. Have fun! :smile:
  • dolbyd
    dolbyd Posts: 430
    edited April 2019
    They do have a five way binding post. You will have to remove the plastic plug.
    I have three atrium 8s on my patio with banana plugs.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
    pitdogg2 Posts: 26,928
    verb wrote: »
    I think what he is saying is the terminals are too close together for the dual banana plugs they already have.
  • verb
    verb Posts: 10,176
    edited April 2019
    Ah! I got it now! :smile: I think! Thanks Ivan!
  • verb
    verb Posts: 10,176
    Jumpers may be the way to go. Male banana or spade on one end, female banana on the other. Hard to find, IIRC.
    Or re-terminate the dual bananas. Either way Bill @bsheckler have fun! Let us know the outcome! :smile:
  • verb
    verb Posts: 10,176
    edited April 2019
    I found something that may work. Not audiophile grade, but heck these are outdoor speakers! :smile:
  • DaveHo
    DaveHo Posts: 3,581
    edited April 2019
    bsheckler wrote: »
    Hello,
    /quote]
    I think this comment originates from the fact that Polk, like many manufacturers, is forced by Euro standards to put plugs in the end of banana jacks to prevent insertion of the standard Euro A/C plug. Just pop the plastic insert out & you're golden.
  • gyosa
    gyosa Posts: 769
    edited April 2019
    Yeah ,
    Make sure you remove that plug under the power port cover if they won’t be exposed to direct rain...
    I have a couple pairs of the atrium 7’s , I think they are ....
    Also have a pair of now discontinued Boston acoustic voyager 7/70’s ...
    Personally I think they sound better ... larger woofer and sealed design.
    You can still find them if you google long enough....
    Also consider the B&W AM-1 .....
    That’s what I would buy next if I needed a new pair of outdoor speakers....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • Thank You for the welcome and the input folks.
    If pole-to-pole spacing is an issue, I can change to single bananas, but they are probably std. spacing.
    I was mostly concerned about space directly across from the terminal openings, as in there was enough space to allow a banana plug to be inserted straight.
    The speakers get deployed (and ideally stowed) about 20 times a year, so ease of connection counts more than normal.
    Best Regards,
    Bil
  • DaveHo
    DaveHo Posts: 3,581
    The connections are angled out slightly. I installed some Atrium 4's for a family member & had no issue using banana plugs.
  • mikey1
    mikey1 Posts: 2
    edited April 2019
    The Polk Audio Atrium 8SDI sounds great. I got two and set them up as a stereo pair outdoors in my yard. They ship w/ the the plastic cover on top of the terminals. Just pop off the little plastic cap and the banana plugs work great. Thank you for pointing that out, bsheckler !!!
  • mikey1
    mikey1 Posts: 2
    @bsheckler, see above for thanks. :-)
    Tony M Posts: 11,567
    Some people don't know the banana plug binding posts have removable plugs in them. ;)
  • Hi PA forum. I just bought some Atrium 6s and after reading this and a few other forums/websites I still don't understand the best practice for connecting cable to these speakers. Banana plugs would be the most convenient, but what prevents that or any other method from corroding over time due to weather? I don't want to use a sealant since I'll be mounting and unmounting the speakers often. If all of the copper wire is inserted into the banana plug and the plug is gold plated, is that enough to prevent corrosion? Maybe there's just something fundamental I don't understand about outdoor speakers. Thanks in advance.
    F1nut Posts: 51,674
    If you're using cheap banana plugs where the wire is inserted then clamped down with a screw use adhesive lined heatshrink to seal banana plug and wire. If you're using higher quality banana plugs where you solder the connection corrosion shouldn't be an issue. However, using the adhesive lined heatshrink is still a good idea.
  • F1nut wrote: »
    Ah, so the banana plug itself isn't a problem and it's just the leak point where the cable is inserted into the back of the plug that I should be worried about?
    I usually use Mediabridge plugs, which don't require soldering but seem better then the cheapo ones with the perpendicular screw. I can still do a heatshrink thing like you mentioned.
  • BlueFox
    BlueFox Posts: 15,251
    Banana plugs are not the best for making a connection. Bare wire, stripped and cleaned, wrapped counter clockwise around speaker connectors is better.
    F1nut Posts: 51,674
    I prefer these. They have a large solid pin through the middle that the blades can rotate around on. The tip with the mass of the pin bottoms out in the binding post resulting in maximum contact. The connection is soldered.
    I strongly disagree that bare wire is better. In fact, I'd say it's the least desirable.
  • F1nut wrote: »
    What brand are those plugs? I can't tell from the photo.
