Help!Possible issues with parasound a23?
Might be something wrong not sure. I have a new to me a23 and I’ve read that they run warm. Mine, when plugged in with nothing connected to it runs really warm on the topside where the heat sinks are located on each side but not in the center. On the bottom side underneath the heat sinks I would say pretty hot. Is this normal? Also when powered off the on/off button glows red not blue and when powered on it glows a brighter red never turning blue after 5 seconds like the Manuel says. Both channel lights glow blue indicating that they are working properly and the overheat light is not on. Any thoughts? I don’t have a way to test it right now with speakers and preamp to put a load on it.
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2019
    mthebull wrote: »
    I would suggest running it in a normal environment. Then see what happens.
  • kharp1
    kharp1 Posts: 3,453
    Nothing connected? No speakers?
  • mthebull
    mthebull Posts: 41
    kharp1 wrote: »
    Nothing connected
  • mthebull
    mthebull Posts: 41
    BlueFox wrote: »
    mthebull wrote: »
    Unfortunately I can’t right now, I just didn’t think it was normal to get that warm/hot without a load and the red light behind the power button making me think it was in circuit protection or something like that. This is all new to me, my first amp so don’t know what the norm should be
  • BlueFox
    Well, running your amp in a unrealistic manner isn’t the best way to evaluate it.
  • mthebull
    mthebull Posts: 41
    BlueFox wrote: »
    Unrealistic meaning plugging it into the wall and hitting the power button?
  • kharp1
    kharp1 Posts: 3,453
    I've never supported turning an amp on without speakers connected.
  • skrol
    skrol Posts: 3,330
    How much space do you have above the amp? After John Curl gave me advice on biasing my HCA-1000A higher, it would get hot in my stereo cabinet with about 2 inches of space above the amp. I moved it out of the cabinet (nothing above) and it runs slightly warm.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • mthebull
    mthebull Posts: 41
    skrol wrote: »
    It’s sitting on a desk in the open
  • mthebull
    mthebull Posts: 41
    kharp1 wrote: »
    I didn’t know it was bad to do this. What’s the reason? I really don’t know
  • BlueFox
    mthebull wrote: »
    BlueFox wrote: »
    Yes, if there is no input or output. You need to ask the manufacturer if your test results are valid.
    Clipdat Posts: 12,559
    Agree with Bud. Reach out to Parasound, they're a friendly bunch.
  • gyosa
    gyosa Posts: 675
    I have an A21....
    I've never used it like you did , but I would think the red light is abnormal ....
    I'd call parasound .... Richard is a great guy to talk to
    Bk
    Parasound A21 , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Yamaha wxc-50 , Boston Acoustic voyager 7’s - POOL
    PS Audio Stellar S300 , Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
    Cambridge Audio 851n - sitting in the closet , for now
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
    DAYENS AMPINO ( thanks Verb ! ) , KEiiD streamer ( this was only 60 bucks ?? ) , Polk atrium 8SDi’s - KID’s BEDROOM
  • mthebull
    mthebull Posts: 41
    Will
    gyosa wrote: »
    I have an A21....
    Bk
    Clipdat wrote: »
    Will do in the am, thanks for the replies.
  • rburgess714
    rburgess714 Posts: 614
    There support outstanding.
    service@parasound.com
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Yamaha BD-S681, Cambridge Audio Azur 851N, Polk S60, Polk S30, Samsung 60" LED
    Office
    Cambridge Audio 851A, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
    F1nut Posts: 49,708
    Never power up a tube amp without a load (speakers) connected. It doesn't matter with solid state amps.
  • mthebull
    mthebull Posts: 41
    That’s what I was thinking with solid state, I think I may have an issue with the amp since it’s glowing red behind the power button instead of blue. Found a couple of old posts that confirm this. Gonna call parasound tomarrow to see what they say.
  • Emlyn
    Emlyn Posts: 4,346
    It's normal for the red LED to come on for a few seconds but then it should turn blue when the circuits are allowed to go active. Consider it like a safety checker. The indicator staying red probably means there is an internal issue that should be fixed. The heatsinks in the A23 are on the outboard sides inside the cabinet. The transformer is in the center and produces no heat. It's not normal for an A23 to run hot unless it has been driving a heavy load.
    My guess is there is a defect in the auto-manual turn on/off circuit. You could flip that switch on the back to its manual (middle position) and see if that resolves the issue temporarily. The LED should turn blue.
    Good call on checking with Parasound. They are very responsive.
  • afterburnt
    afterburnt Posts: 7,892
    @mthebull
    I must ask, why do you have an amp and no speakers?
  • mthebull
    mthebull Posts: 41
    afterburnt wrote: »
    @mthebull
    I have Polk 2.3tl’s but no interconnect and have them apart to start the upgrade process(crossovers, dynamat, hurricane nuts, etc)
  • afterburnt
    @mthebull oh ok, I was starting to think that you were some kind of degenerate freak. I never turn my A31 off so I am not sure how the lights behave but I do think you are having some kind of malfunction.
  • DaveHo
    DaveHo Posts: 3,471
    Everybody who buys used gear should own a multi-meter & a cheap pair of test speakers. Whenever I bring home an amp, assuming it's solid state, the first thing I do is measure the DC offset, then it gets connected to the test speakers and played for a couple hours before connecting to anything else. Doesn't need to be anything fancy, mine are a pair of RatShack Minumus 7's. Time to hit up craigslist.
  • mthebull
    mthebull Posts: 41
    afterburnt wrote: »
    Spoke with parasound , tech said it could be as simple as blue led burnt out, or internal issues. I’m gonna find a cheap speaker so I can test and see if I get sound.
  • mthebull
    mthebull Posts: 41
    DaveHo wrote: »
    Good advice, I’m learning!
  • afterburnt
    mthebull wrote: »
    afterburnt wrote: »
    One should always have a bunch of junk speakers around. I know I do.
  • mthebull
    mthebull Posts: 41
    I guess sometimes you just get complacent, I’ve never had an issue with buying used. This may be the first :(
  • gyosa
    gyosa Posts: 675
    edited April 2019
    When I turn on my a21 it goes red for a second or two then straight to blue ....
    But , it is on a trigger, so always in standby...
    Bk
  • mdaudioguy
    mdaudioguy Posts: 5,165
    afterburnt wrote: »
    @mthebull
    His speakers were so good, they just disappeared in his room...
  • mthebull
    mthebull Posts: 41
    mdaudioguy wrote: »
    afterburnt wrote: »
    @mthebull
    Ok... yeah they are soooo good B)
