Connect DAC to preamp and headphone amp simultaneously
Clipdat
I'm feeling stupid, so I'm reaching out for help! I'm trying to figure out how to have my computer's DAC connected to both my preamp and a headphone amp at the same time.
The back of the DAC has your standard L & R RCA outputs, which is currently connected to the preamp using a RCA to 3.5mm female cable, since the preamp's input is a male 3.5mm connector. (2.1 powered desktop speakers, designed to be plugged into a computer.)
I would like to be able to connect the DAC to both the speaker preamp, and a headphone amp that has a standard L & R RCA input, so that I don't have to physically disconnect the preamp, and connect the headphone amp to the DAC using a cable like this every time which is what I have been doing I want to listen to headphones.
What's the best way to have the output of the DAC hooked up simultaneously to two destinations as I described? Preferably without adding too many adapters in the signal path!
Another forum recommended using these on the back of the DAC:
Reviews warn of a noticeable decrease in sound quality. -
Internal DAC? Is USB out an option?
It's an external DAC connected with USB.
Any splitter you use will probably degrade the signal significantly. If you have no other output, other than the one USB , there may be no other option than splitting or switching.
Ah, I see what you meant earlier. Using the computer's built in DAC to go straight to the headphone amp, leaving the USB DAC connected to the powered speakers.
That's certainly an option, although I'm not a huge fan of the sound of the built in DAC on this motherboard. Despite claims of it being "good". -
I got a neat little DAC that has a headphone out, it's that Pro-Ject Pre Box thingy. I never tried it with cans. I forgot about it when I got the Cambridge streamer. I can't remember when I listened to cans it that room. I use an Ifi micro for cans in the other room and it's cool for me, I am not very demanding when I want to tune in and drop out.
What was the question? -
I was looking at those for my Bottlehead since it only has one set of RCA outputs. Interesting that they claim degradation of sound quality. Got me thinking as to why? Hmmm.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Ohms law. -
How about using a Schiit SYS as a selector switch. A new one is $49. I think it can be used with signals reversed"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
I'd rather just manually swap cables versus giving any money to Schiit, or using any of their products whatsoever.
What happened? I thought you were a fan of Schiit? -
Nothing happened, I'm just not interested in owning any of their gear moving forward.
