new to Polks...Just picked up a pair of SDA1B's...to mod or not to mod....
2
  • codycatalist
    codycatalist Posts: 2,662
    B&K is another good option. Re. Adcom's lack of speaker protection, keep in mind the missing protection is if something internally goes wrong with the amp and it blows it WILL send the DC to your speakers. There are a couple of ways to combat that, a speaker switch is one (although I wouldn't advise one as it will introduce more to the signal path). There are upgrades that will add speaker protection to your Adcom as well.
    I have only had a couple of issues with my GFA545 but they all involve me being stupid and all that happened was I blew a fuse in the amp channel.
  • haha..ok...good to know...
    I was just thinking..
    as far as preamps go, is there any real downside to just getting a nice surround sound receiver with preouts and using it as a preamp? that way I could still use the channels from the receiver's power amp for some small speakers for tv/movies/whatever and use the preout and separate power amp to drive my big **** polks for listening to music...or is there a real noticeable difference when getting a dedicated 2 channel preamp?
  • codycatalist
    edited April 2019
    Is there a difference...yes. I have (and currently am) using an AVR pre outs to a 2 channel amp which is powering my 2.2 HT. Like they say an AVR is a Jack Of All Trades, Master Of None. Will it work and possibly sound pretty good, yes. Will it be taken to a different level with a dedicated 2 channel pre, yes.
    That being said there are plenty Processors from reputable companies that sound great in 2 channel and can do HT as well.
    The world is your oyster... Shuck it.
    audioluvr Posts: 5,920
    All depends on your perception of " good enough" as listening to music goes. Some people are perfectly happy listening to a boom box. Let your ears choose. Don't rely solely on others opinions. Vintage electronic over 20 years old often sound dull compared to more modern electronics. It's all a journey.
  • Schurkey
    Schurkey Posts: 2,122
    When it was me, I bought a real HT processor (not a HT receiver) and separate power amps. I just don't see any reason to screw around with receivers if sound quality is important. The whole point of receivers is to market a product with as many compromises as the market will bear in order to drop the price.
    It doesn't HAVE to be that way, but that's the way it functions now.
  • gotcha....this all makes sense. I'll continue the search for a decent 2 ch preamp...I've been looking at Adcoms and Nad's...they seem fairly affordable.
  • codycatalist
    Take a look at the older Denon PRA Preamps. They are cheap and sound nice.
  • lawdogg
    lawdogg Posts: 468
    I've been using a Yamaha RX-V665 into a variety of 2-channel amps with my 3.1TLs with no complaints. The V665 is pretty awesome.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • Take a look at the older Denon PRA Preamps. They are cheap and sound nice.
    yeah..something like that looks nice...I would like something relatively newer so I don't have to worry about doing a total overhaul or anything like that...but mainly..i want a remote...haha...
    I'm really considering just trying out a real high end (older) Denon, Yamaha, Marantz, HK, etc audio video receiver with pre outs. You can get fairly high end stuff for $100-200 on craigslist due to a lack of some modern video or surround sound feature that I could care less about. I really can't imagine that a separate preamp from 80's is going to sound 10 times better..
  • ok...i'm just wondering what you guys think of this...
    I'm probably going to get an Adcom GFA-555 and GTP-500..in fact, I found two of them together 4-5 hours from me. Anyways, I'm pretty sure i've decided on the power amp..just not sure of the preamp yet...
    would you recommend I get an Adcom GTP-500, or a Marantz AV7005 processor that I found on Facebook Marketplace for $300 asking price. I'm tempted to get the Adcom because it's a purpose build preamp for listening to music with a phono section (apparently a good one too) and a remote...but that Marantz is newish and has everything I need (and more). ..wouldn't the more modern Marantz sound better? They make pretty damn good stuff..
  • jimmylee123
    jimmylee123 Posts: 105
    Bruh, listen to them first for a bit.. See if you like them.
  • the guy with the adcom gfa 555 just told me that it's been on for almost 20 years straight and he has only turned it off a few times for a power outage...is this guy totally insane or is there something I don't know about high current amps?
  • codycatalist
    I wouldn't make that assumption, every separate preamp I have heard regardless of age sounded better than an AVR.
    I haven't had the experience but from what I have read pairing Adcom Amps and Pre's usually doesn't sound too great unless you go the TOTL Adcom Pre.
    Constantly turning on and turning off a high current amp can shorten the life span as the sudden jolt to charge up the capacitors is a bit harsh on the caps.
    pitdogg2 Posts: 27,061
    Many keep power amps on constantly, that being said the 555 is about ready for new caps. Very easy to work on.
  • wow...I did not know this...it kind of scared me away from it honestly, but I trust your opinions...that's why I'm here..haha..
    is that super draining on electricity or the opposite since you're not constantly charging up those giant caps?
  • also....probably another newbie question...i'm way more familiar with car audio and pro audio (i'm a musician by trade)
    with pro audio, you typically have to turn the pre amps on first, then turn the power amps on, otherwise you get a big pop that can damage your guitar cab, PA speakers, or whatever you're using...is it not the same with this stuff? I would have guessed I would have had to had the same powering on procedure....when turning on: pre amp first, then power amp....and when turning off...power amp first, then pre...to avoid the popping..
  • verb
    verb Posts: 10,176
    boston1450 wrote: »
    Nice list you have going.... Here is a quick list of amplifiers i have & had & used on SDA's. Parasound 2250. Acurus 200×3 (sweet amp). Had Adcom 555 & 545. Denon POA2200 (sweet amp). Most all i did with seperates & could be used in HTfronts set up. All i listed never broke a sweat with SDA 1c 2B or Crs+ speakers. I did have a McIntosh 100wpc amp i never used on SDA's & i also had a NAD & Carver AVR100 (sweet) i used on B&W speakers & other Monitor Lsi speakers. So much out there. SDA's sound awesome on tube amps too :) . Keep in mind older amps may be due for refresh & some like the Adcom 555 can be upgraded. If the price is right & you got a local tech or DIY - you are styling. BTW lets not forget some Carver amps i hear about on CPolk. So many temptations
    Dude that's a lot of amps! :smile:
  • codycatalist
    Yes same process in this game as well. Not all amps have this characteristic but if you are going Adcom then yes Source/Preamp turn on > Amp turn on > Amp turn off (wait for the caps to discharge) > Source/Preamp off.
    I personally DON'T leave my Adcom on all the time but that is due to lack of speaker protection and the fact I don't get to listen as much as I would like. I wouldn't worry about your electric bill going up keeping these on, they aren't 1000 watt Class A Monoblocks.
  • boston1450
    boston1450 Posts: 7,758
    verb wrote: »
    boston1450 wrote: »
    Ive had more. Heck i got the McIntosh for 25.00 mint with manual from a brain surgeon Dr :)
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    edited April 2019
    im not sure where you may have read the info on Adcoms. MY experience with Adcoms is different. Ive had 3-4 different preamps on Adcom amps ive owned. Both the 545 555 on SDA 1C 2b Crs+ & other brand speakers including 901 Bose (that explains it) speakers and with each lower end preamps & they all sounded pretty darn good for a amp under lets say 300 for amp & preamp. ... Heck i did some reading on the original Klipsch Heresys & they had bad reviews. I then paid 400.00 (mint/boxes) & hooked them to Yaqin MS30L tube amp with Yaqin tube cd player. Wow they sounded very good. Go n listen to it set up & let your ears decide. There are lots of amplifiers out there if its not for you
    Post edited by boston1450 on
    Randy-Maine
    by David WMG
  • boston1450
    edited April 2019
    Opps. Already answered
    Randy-Maine
    by David WMG
  • codycatalist
    boston1450 wrote: »
    Yeah that's why I had the disclaimer of not my experience lol. Just some things I read when I first got my GFA, I figure it's better to inform under the context of "whispers from the outside" than not.
    I guess that's what keeps this whole thing fun is how different opinions and experiences can be.
  • boston1450
    What Adcom you using ? I have always wanted to listen to a Gfa535 with some small bookies. Ive heard its quite the little amplifier. Maybe someday
    Randy-Maine
    by David WMG
  • codycatalist
    boston1450 wrote: »
    I have the 545 MK1, it works well in my room as the room isn't too big and this gives enough juice to get the SDAs to open up.
  • thanks guys...this is super helpful..I'm still thinking it over, but I think I might make the drive and pick up this combo...it seems like a good introduction for me to the world of separates...I don't have a super huge budget, and I love getting a lot for my money and I keep reading that these amps are pretty amazing for the money. However, it's an 8 hour drive round trip..haha...but if I can get the amp and preamp (both of which are the ones I've mainly been looking for), remote, original brochures, all in good shape from what I believe is the original owner for around $400, I should probably do this, right?
  • hmm...I just found an Aragon 4004 Mark II near me for $600....anyone know anything about these? and are they common ground?
    Very nice amp. IIRC they are not but can have the grounds strapped together for common ground.
    I'd reach out to Aragon in Indianapolis Indiana for confirmation.
