Bluetooth Integrated
codycatalist
Looking for a cheap Bluetooth integrated. SQ is not a concern. Figured I would see if anyone has one to sell before I hit the bay. This is to power two outdoor speakers, amp will be inside house.
Thanks!
Thanks!
Picked one these for my ex gf and paired with some Signature 15s not a bad little unit for 2 bones.
https://www.accessories4less.com/make-a-store/item/yamrn303bl/yamaha-r-n303-2-ch-x-100-watts-networking-stereo-receiver/1.htmlLiving Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Yamaha BD-S681, Cambridge Audio Azur 851N, Polk S60, Polk S30, Samsung 60" LED
Office
Cambridge Audio 851A, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
Yeah for that budget used or new my options are wide open. So far my leafing candidate is a little nobsound with built in Bluetooth for 50 bucks.
Ain't gonna be the best sound wise but cheap, small foot print and will do its job.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I have a Pioneer SX-N30 in the living room. BT works great. Has network capability and preamp outputs if needed. 2 hundie all day long on line.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Another alternative would be to use an existing receiver (if you're like most of us you probably have several) and get a decent BT receiver. I have the Audioengine B1 and also the Pro-Ject BT Box. Both have the AptX codec, and work great!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
^^^ yeah, this. In early days, I used to use some IOGEAR BT receivers, and they worked pretty well. Didn't seem to range past 15ft-ish, but the Audioengine B1 is supposed to offer great range, as well as aptX for better sound quality, even though you say you're not shopping for it.I disabled signatures.
@verb Good point, let me talk to the receiving party to get a feel for their budget. The Pio is a huge step up obviously, I will have to play the longevity vs small term cost savings card.Just a dude doing dude-ly things
