Bluetooth Integrated
Looking for a cheap Bluetooth integrated. SQ is not a concern. Figured I would see if anyone has one to sell before I hit the bay. This is to power two outdoor speakers, amp will be inside house.
Thanks!
  • rburgess714
    rburgess714 Posts: 618
    Picked one these for my ex gf and paired with some Signature 15s not a bad little unit for 2 bones.
    https://www.accessories4less.com/make-a-store/item/yamrn303bl/yamaha-r-n303-2-ch-x-100-watts-networking-stereo-receiver/1.html
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • codycatalist
    codycatalist Posts: 2,661
    Yeah for that budget used or new my options are wide open. So far my leafing candidate is a little nobsound with built in Bluetooth for 50 bucks.
    Ain't gonna be the best sound wise but cheap, small foot print and will do its job.
  • verb
    verb Posts: 10,176
    I have a Pioneer SX-N30 in the living room. BT works great. Has network capability and preamp outputs if needed. 2 hundie all day long on line.
  • verb
    verb Posts: 10,176
    Another alternative would be to use an existing receiver (if you're like most of us you probably have several) and get a decent BT receiver. I have the Audioengine B1 and also the Pro-Ject BT Box. Both have the AptX codec, and work great! :smile:
    msg Posts: 10,534
    ^^^ yeah, this. In early days, I used to use some IOGEAR BT receivers, and they worked pretty well. Didn't seem to range past 15ft-ish, but the Audioengine B1 is supposed to offer great range, as well as aptX for better sound quality, even though you say you're not shopping for it.
  • codycatalist
    edited April 2019
    @verb Good point, let me talk to the receiving party to get a feel for their budget. The Pio is a huge step up obviously, I will have to play the longevity vs small term cost savings card.
