Rear surround shopping..
speedtoys
Hello:
I've recently rebuild a pair of 2.3TLs with the VR3 kit, and I have a Bob Carver Sunfire Cinema Grand Signature 400 ~ 5 on the way.
My sub is driven by a Velodyne SC-600d to a Hsu Research tube sub.
I -may- use my 2Bs as side surround drivers, but I have no rear surrounds.
I live in an apt, I cant go INTO the walls, but can mount to them. I can't do anything with the ceiling..concrete.
I've spent bout all my $ of the amp and 2.3 rebuilds, so I dont want to get too crazy with the costs on a simple pair of rear surrounds.
TV to the rear of the room, is maybe..15'?
5jr's?Don't take experimental gene therapies from known eugenicists.
or 5B's on stands. Nothing bigger, I'd think
No room for stands...would in -in- the walkway between the couch and the rear wall/counter space.
Gonna have to be up on the wall high....and an ugly run of cable to get there.
Would you really notice the difference having 7.1 vs 5.1 in that space?
I personally don't find a need to timbre match the surrounds. I would go FXIs and not look back.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Fxi500 or 1000 would be a good match.
I had both of these and really like them until I came across a set of Definitive technology BPVX/P's...these sound amazingly better!!! -
My question would be if you have the room to support rear surrounds? If the couch is against the rear wall or less than 1-2 feet, stick with the 5.1 setup. I suggest having around 5+ feet behind the couch to really get that true surround immersive feel. The space distance gives you that come from behind/fly over experience.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
