Old to the world but new to me
Geoff4rfc
Geoff4rfc Posts: 2,899
Got a great deal from AC4L, getting installed this weekend.
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • verb
    verb Posts: 10,176
    Nice! :smile: Looks like this weekend is gonna be a lot of fun!
    EndersShadow Posts: 17,713
    So.... I see two sub outs..... those Epiks finally getting unboxed?
  • Geoff4rfc
    Those Epiks would love to play, but...….sadly, no.
    Set up:
  • aprazer402
    aprazer402 Posts: 3,400
    I too have an Epik Empire. Brand new still in box, never unboxed. I bought it the first week they were announced. I'm guessing it should be okay if stored at normal indoor temp. and low humidity. @Geoff4rfc have you ever used yours? I've read of amp failure issues. But others have said as long as you don't turn it way up you should be okay. Thank you.
  • Geoff4rfc
    aprazer402 wrote: »
    Yes indeed! Both of mine have been in full swing and produced very impressive results. Both have had their amps replaced. The first one lasted just under a year, the second one got replaced in the first week. Neither of mine were turned up very much.
    The amp failure was a common occurrence, which I believe was the reason Chad folded his tents, he was replacing the failed amps with better amps at no additional charge to the purchaser...…..that was a lot of amps......
    Set up:
  • aprazer402
    Thank you so much for the reply. I've enjoyed your racing posts. Well it sounds like I can expect an amp failure as mine was probably one of the early ones made. I haven't looked at any other forums lately for advice regarding replacements because mine is still unused and will probably remain that way for some time. Maybe this Chad fellow will resurface with another audio firm and have a simple solution. But in this hobby simple solutions can get ugly or simply be not feasible. I can always sell it down the road. It's too big for a boat anchor, it would sink the boat. Thanks again. :)
  • Geoff4rfc
    aprazer402 wrote: »
    Thanks for the kind words! Too bad you're unable to take advantage of it, they are pretty decent subs! If you end up keeping it and run into trouble, replacing the amp is pretty straight forward. Once you have the replacement, it's just two wires, snip, strip and splice :)
    Set up:
  • aprazer402
    That's good to know. I thought there would be issues with getting the size right to fit the opening... I'll ask for help again when needed. That's what this forum is about. Thank you again.
  • Geoff4rfc
    Pre install prep......just 8 caps short of complete....
    Set up:
    msg Posts: 10,452
    That's a real beaute, Geoff. I don't think I knew Onkyo made processor-only units. I've always liked Onkyo, but only ever had stereo receivers and never managed to land one of the big AVRs. If/when my current processor kicks it, I'll have a look at something like this. Pretty cool, and looks very capable.
    Looking forward to hearing how you like it.
    @aprazer402
    I’ve seen folks rewire it so you can hook it up to a pro amp for power.
    And if you’re thinking of your offloading it, where do you live lol
    @msg
    You gotta be careful with those units. They stopped using Audyssey recently and were using their own in house EQ which I know little about.
  • aprazer402
    @aprazer402
    @msg
    Not ready to part with it yet. Omaha, NE. Just a tad over 600 miles from Indy. :)
    Yup lol...... too far :smile:
    If you need help with the wiring to hook up a pro amp let me know.
  • honestaquarian
    honestaquarian Posts: 3,258
    edited April 2019
    Good stuff that. I have the Onkyo equivalent.
    If you want to get HDradio you can use the U-port and hook up an Onkyo HDradio tuner module. Good luck trying to find one though. I LOVE HDradio!
    Also be mindful of the HDMI board and audio chip issues that these units have had in the past. Onkyo has a free fix for the audio chip. Not sure about the HDMI board though.
    I had an Onkyo PR-SC5508 pre/pro that had the board issue and Onkyo replaced it with a PR-SC5509 for free when they couldn't get the parts in a timely manner, even though the unit was just out of warranty (and I had purchased it from a4l like you did)
    The audio chip went down on my 5509 and Onkyo fixed it for free. You have to ship it to them do do that though. No charge for any of that.
  • Geoff4rfc
    edited April 2019
    msg wrote: »
    Thanks brother, by the way, it's an Integra, the glorified Onkyo :smile:
    So far so good, using one RCA since one of my 7 Balanced I.C's were too short. Using shielded, 16 gauge shielded copper conductors with gold plated connectors on the Bal. XLR's.
    Impressed with the sound, MultEQXT32 with this one like my DTR70.4, edges it out on sound, about the same on P.Q.
    Had some handshake issues at first during initial set up they finally cleared!
    Nice! Yeah, I still have an Onkyo TXNR807, also suffered HDMI woes, got an out of warranty fix for that, know the drill.
    I purchased the extra warranty on this one so I should be good, plus I use a laptop fan on a few of my units that like to put out heat, keeps em cool to the touch.
    Set up:
    edited April 2019
    Got me thinking about replacing my Denon X4100w with a 80.3
    msg Posts: 10,452
    Well, Geoff?!? How is it?
    msg Posts: 10,452
    Found your other tred!
