Bi-wire connectors for RTI70 Speakers
steiny7221
I know I used to have metal plates that would bi-wire my RTI70 speakers, but can't locate them. Does anyone know if Polk Audio sells that small part? I can obviously just route more wires between my receiver and speaker, but would prefer to just run a single wire, and use the connectors. Thanks!
If I understand your question correctly, you're looking for something like this:
You're actually better off with this:
Do what Tony says, use speaker cable for the jumpers.Political Correctness'.........defined
President of Club Polk -
Thanks guys! This is what I’m doing. I shouldn’t worry about it any further. It’s just bothering me that I can’t find those.
