Bi-wire connectors for RTI70 Speakers
I know I used to have metal plates that would bi-wire my RTI70 speakers, but can't locate them. Does anyone know if Polk Audio sells that small part? I can obviously just route more wires between my receiver and speaker, but would prefer to just run a single wire, and use the connectors. Thanks!
  • tonyp063
    tonyp063 Posts: 1,135
    If I understand your question correctly, you're looking for something like this:
    You're actually better off with this:
    F1nut Posts: 51,912
    edited April 2019
    Do what Tony says, use speaker cable for the jumpers.
  • Thanks guys! This is what I’m doing. I shouldn’t worry about it any further. It’s just bothering me that I can’t find those.
