PS Audio P3 AC Power filter and Regenerator
doctorcilantro
-1st owner
-Aesthetic flaws on faceplate (I tipped over bronze statue that scraped the chassis above the LED screen - small marks on chassis to the right of LED from carrying in baggage - these flaws are very hard to see when you are more than 6-7 feet away tbh - the scratch blends into the look of the LED screen))
-Remote control is missing the back cover
-Selling as I am moving to a 220v home
-Ethernet Controls
-Including a .5m Signal Cable power cord
Asking $1400 shipped net total anywhere in the USA.
The smallest and most affordable of our personal power generating stations, the P3 produces pure, protected AC capable of powering any size high-end system. This state-of-the-art power center offers fully regenerated power for all sources and smaller power amplifiers along with a high current filtered output that can drive even the largest power amplifiers made.
From the biggest power amplifiers to the smallest pieces of source equipment, this combination of regenerated AC coupled with a high current unrestricted filtered zone will work magic on your system’s performance.
With your system powered directly from the output of the P3, dynamics and openness are unquestioned.
thanks!
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Nice!
Those damn bronze statues... get'cha every time.I disabled signatures. -
PS audio may be able to provide a new faceplate for that.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
If this was Black I would probably jump
GLWTS -
Thanks, not sure if the faceplate can be replaced. It's a full unified chassis it seems....For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
Joe, you pay for this, and I'll give you my black PSA PowerPlay IPC-9000joecoulson wrote: »If this was Black I would probably jump
GLWTS
doctorcilantro wrote: »Thanks, not sure if the faceplate can be replaced. It's a full unified chassis it seems....
You could just give them a call and ask...
**EDIT**Just got off the phone with them... they trashed all the old parts for this unit when they moved buildings, so no cosmetic parts are available for it any longer.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Jody, um no.
nooshinjohn wrote: »doctorcilantro wrote: »Thanks, not sure if the faceplate can be replaced. It's a full unified chassis it seems....
Trash OEM parts? Rarely a wise decision. -
It likely wasn't a large amount... can't expect them to foresee the damage caused by a bronze statue.
Bronze statute foreseen or not, rarely a wise move to throw away new inventory. I'm surprised PS Audio would do that, as their customer support is really good. Imagine how incensed we would be to find out Polk had trashed a bunch of passive radiators for SRS 2.3's ...
My cabinet touch up guy could wax burn in and touch that up in a jif
I hate that statue, whatever the f$#@ it's made of.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
