SDA SRS 2 Tweeter replacement
edwardsprague
I purchased the 194 tweeters to drop into my SDA SRS 2'S. The tabs (terminals) on the tweeters are silver and red. The wires in speakers are black and white. Please let me know which colored wire goes to which terminal. Thank you
Best Answer
Red = +
Silver = -
Answers
Black wire to red terminal.
Thank you.
Wow, just removed other Tweeter and wires are blue and green. A little help here too would be appreciated.
Blue + positive
Green -- negetive
Most just do not use the dimensional tweeter fwiw
What terminal on Tweeter is considered positive, red or black. Thank you
Red
Thanks again
Blue wire to red terminal.
Why are you not looking at the wires as you're disconnecting them? Do you not trust them to be on the proper terminals of the original tweeters? -
The terminals on the original Tweeter is not red and silver
edwardsprague wrote: »The terminals on the original Tweeter is not red and silver
Correct the plus and negetive were very visable and clearly molded into the bezel. -
Thank you for all your help. Will be more careful on the other speaker. Thanks again
