Your mower of choice?
Some of you may hire a company to take care of your grass, some may even have it included in your HOA/Condo fees, and maybe even some of you don't even have any grass to cut? (lucky you)
For me, I both enjoy and hate cutting my yard. But I have just purchased the mower to rule them all (not really - just nicer than the old one).
This got me curious what mowers you guys use out there?
«134
  • displayname
    displayname Posts: 1,236
    I haven't had a new mower in awhile, but if I was buying a new one I might consider the self propelled electric ones. Just being able to hear myself think with some headphones on sounds nice. No idea how they hold up over time though.
    Discogs
  • mark090852
    mark090852 Posts: 998
    edited March 2019
    I used to enjoy mowing the grass, but eventually got to the point where I was too busy. Plus, it always rains here in central PA and my time never matched the limited dry time we would have. So I sold my mower and we will be moving to western Colorado in a few months where our landscaping is "high desert xeriscaping". No grass to mow! Yeah!
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • rpf65
    rpf65 Posts: 2,127
    Replaced my mower, that commuted suicide, a couple of years ago. Picked up a John Deere D-105 on sale for $250 off.
  • charley95
    charley95 Posts: 908
    Honda all the way for me! 5 yrs. so far with mine and no complaints, worth the extra $$. Always starts and the dual blades give a nice cut.
  • JPete
    JPete Posts: 298
    edited March 2019
    Craftsman rider and push mower here. Both over 12yrs old now and still do what they're supposed to. When the time comes, I'll probably look at one of these:
    https://www.husqvarna.com/us/products/riders/r-322t-awd/967032102/
    I could use 4wd or at least a zero turn to help stability on the hills.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • Mikey081057
    Mikey081057 Posts: 7,127
    I had a lawn service and fired them.... I've been cutting my own grass with a 22" Husqvarna with a Honda engine... It has 4 wheel drive and is a good mower.However I am considering a 42" ZT mower of which brand I haven't decided yet because cutting grass here in summer is very tough... between the heat and the rain... I'm getting too old to cut in the summer.
    Garage | Polk Monitor 5B's
  • Jstas
    Jstas Posts: 14,996
    I actually have two but the second one is not nearly as much of a hoss as the first one.
    Still, bright orange...needs tiger stripes, I think. A project for next winter, maybe?
    Oh, second one is a used Ariens that needs a governor fixed. Has a 597cc 18 HP Kohler Courage engine. Geared transaxle. Single cylinder, decent enough for lawn mowing, likes to bog down in real thick/heavy stuff. Not the best for anything else except towing a trailer of yard materials/waste or firewood or something.
    First one is an old Craftsman LT1000 something or other. It blew it's engine a couple years ago so I got a new one. It's bigger with 3 more HP than the old one and I actually had to build custom exhaust headers to get them to fit the muffler location. But at 724cc with 24 horsepower and a hydrostatic transaxle, it's got some grunt. Enough to run a 42" wide, 16 inch tall snow thrower attachment.
    And yeah, no real brand loyalty, just whatever I can get cheap with the power/options I want. If it's broke, I'll fix it. That's how I got the Ariens.
    Expert Moron Extraordinaire
  • Mikey081057
    pitdogg2 Posts: 27,341
    Ride or walk Joe?
    treitz3 Posts: 20,123
    While it's not a mower of choice, my tractor is a Cub Cadet. Decent enough but it still takes me 3 1/2 hours to mow the lawn. Will most likely get a stand up Zero turn or one that has a wider swath. 42" just ain't cuttin' it quick enough. It's gonna be expensive because I have the bagger (as pictured below), front bumper and custom built a rack to toe a utility trailer as well as the regular dump trailer/seeder/aerator.
    5bcd13c8af3da15146361230.jpg?width=1024&height=768&quality=70&upsize=true
    It looks like the one pictured above. Decent mower for the price and I use it and abuse it pretty hard. *knock on wood* No major repairs so far but been through a lot of blades, spindles, bearings, etc. to keep the cut optimum.
    It's pretty easy to work on right up to the point to where you have to change the drive belt. That one was a little tricky but as soon as I used a mirror to see what kind of bolt size was under the seat (and metal frame) that held the pully, I was golden. They make these damned things to where they want you to go to a service shop. When you have to mow your yard twice a week during the busy season, no can do. It needs to be up and running asap!
    I'd give it a 5 start rating, given how I abuse it beyond what it was built for. This thing does move a LOT of weight....I'll give it that. It'll do a pretty good job of cutting overgrown tall grass too, provided it's not wet grass.
    F1nut Posts: 52,009
    Nothing runs like Deere.
  • Mikey081057
    I like this
    Tony M Posts: 11,734
    I know you just bought a new one. What kind and how big?
    Ours: A Toro walk behind. Personal pace self propelled. I give this thing 6 stars on a 1-5 scale. :p;)
    I have a small yard as you guys have probably seen. This was a one pull start for about 5 years :) before it needed a couple more pulls. This year to start, but it was bone dry, took 8 pulls after I put gas in it. Next time it might be 2 to 3 pulls probably. This is ours and we did get new from Home Depot on sale.
    https://www.homedepot.com/p/Toro-Recycler-22-in-Briggs-and-Stratton-Personal-Pace-Self-Propelled-Gas-Walk-Behind-Lawn-Mower-with-Electric-Start-20334/100659631
    BEST mower I've ever walked behind. I'm sure Honda's are just as nice.
    3 1/2 hours and you have a rider? OUCH. Yea, that 42"er needs to be replaced with a 60"er. :D
    FYI.... https://www.youtube.com/watch?v=aF58awcVY98
    https://www.wrightmfg.com/products/mowers/commercial/stand-on/stander-x/
    This is what I have been eying lately. This should last me a lifetime, where as most mowers (Including the John Deere), the manufacturers stop making parts for the mowers after 7 to 10 years. 3 of my neighbors have recently found this out and had to buy new tractors. All 3 had transmission issues. My other neighbor had this happen with his Husquvarna (sp?) too but he is a whiz at mechanical stuff. He custom fit a newer tranny on his 13 year old tractor.
    I was planning on custom making a tow bar for it. Costs a little bit more but my landscaper has one like this and he was able to mow the lawn in a little over an hour. My kind of mower!!!
    FWIW...
  • dolbyd
    dolbyd Posts: 430
    Toro commercial with the Honda engine for an average yard. Mine is 20 years old.
    eXmark if you have acreage to mow. We have them at work and they can handle everything.
    When you use commercial equipment at work you can’t go cheap at home.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    Begin rant... how about a mower that has a gas cap that actually has a few rows of threads to screw it on at least 2 full 360 degree turns instead of a half row of threads where the cap only turns about an 1/8 of a turn! >:) .....end rant.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Mikey081057
    I just went down to the local dealer and bought the Exmark. It's nice that they are like 2 miles away and come to you to do service. I was amazed that the place was as clean and nice as the Lexus dealer....added a mulching kit.
    https://www.youtube.com/watch?v=fEePbakTV1A
  • joecoulson
    joecoulson Posts: 4,943
    So I had the Troybilt Pony for about 5 years and it has been a good little workhorse. I really wanted to upgrade it over the years but since it ran so well it seem like a waste of money. However my father-in-law still uses a walk behind mower and his knees are giving out on him. So we decided to give him our mower and I got a new one :#
    So we got this beauty:
  • jflail2
    jflail2 Posts: 2,868
    Loved my Honda push mower; never had a single problem with it. I'm in a city house now so sold the Honda to my old neighbor and am cutting the grass with a weed eater. Takes about 15-20 minutes!
  • tratliff
    tratliff Posts: 1,811
    I picked up one of these last year. Sure has reduced my mowing time.
  • Polkitup2
    Polkitup2 Posts: 1,642
    Been running my same Deere rider for 18 years with no issues. Should have many years left in it.
  • Conradicles
    Conradicles Posts: 6,379
    Push mow, Husqvarna AWD. Great exercise on these giant hills I live on!
  • joecoulson
    tratliff wrote: »
    NO doubt! usually it too me over an hour to mow the front and back - sometimes more in the late summer when grass is growing like mad
    yesterday i ran through both in 20 mins
    wowzer!
    audioluvr Posts: 5,990
    Cub Cadet. Bought the self propelled one in '87 and still starts on the first pull. Had a Craftsman rider for 28 years and when it finally ship the bed 3 years ago I replaced it with a new XT1 with the 24hp Kohler (Cummins owns Kohler). Love that thing. Bought the snow blower attachment and enclosed cab for it the following year so this thing works hard year around.
  • Thorton
    Thorton Posts: 1,324
    I've owned this for about 9-10 years. Excellent machine.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • deronb1
    deronb1 Posts: 5,021
    Husqvarna push with Honda engine as well. Only have 1/4 acre and takes 45-50 min.
  • mrbiron
    mrbiron Posts: 5,721
    My Deere X350 was bundled with the sale of my house.
    Will most likely buy another one. May look at zero turn...
  • OleBoot
    OleBoot Posts: 3,135
    My mower of choice is the guy that charges us $35 for mowing an acre of grass.
  • Dabutcher
    Dabutcher Posts: 2,606
    edited March 2019
    Last season I bought a husqvarna off Amazon with a Honda motor. Self propelled. Not AWD. Very heavy duty. Bought a new Lawn Boy the season before that, because I always had the 2 stroke ones. New LB’s are junk! Everything is plastic. Husky was night and day better made. Good luck. D
