DIY Headphone Rack
zingo
zingo Posts: 11,258
I started this rack last night out of 3/4” finished plywood. Next I will band the ends so all surfaces are finished, and then create some cable management for the back side.
I was worried about the heat created by the amp, so it worked out to have it on top of the stack.
More to come...
  • ALL212
    ALL212 Posts: 1,658
    Nicely thought out - Route the top edges where the headphones hang so they're rounded?
    Aaron
    Enabler Extraordinaire
    EndersShadow Posts: 17,704
    When do you start taking order 😜
    msg Posts: 10,452
    dude, nice! Timely post, too, 'cause I was thinking I should graduate to having some fancy head shaped thing to put my headphones on instead of a desk/spare mousepad/microfiber cloth.
    I think that thing needs brass spikes next.
    But not sure, should headphone racks/stands be coupled or de-coupled?
    Maybe some nice rubber feet or felt sliders?
    https://www.amazon.com/gp/product/B0080HII18
  • zingo
    zingo Posts: 11,258
    I do need to finish the top and was maybe thinking felt.
    msg Posts: 10,452
    For some odd reason I'm thinking this piece should be flanked by twin Lava Lamps during listening sessions...
  • verb
    verb Posts: 10,176
    Clever design. Looks portable, too! Like it! :smile:
  • DaveHo
    DaveHo Posts: 3,583
  • zingo
    zingo Posts: 11,258
    I put rubber feet on each component and on the bottom of the rack to isolate it from the table/counter.
  • zingo
    zingo Posts: 11,258
    Brown leather wrap for the top handle/headphone rest?
    Tony M Posts: 11,623
    I love it when people design and build their own things that they want or need. You planned it out and built it. That's COOL! B);)
    What did you cut that plywood with?
  • zingo
    zingo Posts: 11,258
    Combination of table saw and sliding chop saw. I’m just trying to figure out how I want to finish the top and break the edge where I hang my headphones.
  • pumpkinman
    pumpkinman Posts: 10,233
    Very nice job B)
    Because I am The Pumpkinking
  • zingo
    zingo Posts: 11,258
    It took a while, but I finally veneered the cut edges and wrapped the top in leather; it provides a soft rest for the headphones and for picking up the rack. It’s not a flawless project, but I love how it turned out and provides a tidy and compact place to hold my headphone equipment.
  • ALL212
    ALL212 Posts: 1,658
    Aaron
