Wanted: Donations of Magnet-Shifted Drivers for my FREE Polk Driver Exchange service
WasecaTech wrote: »I'm preparing to retweet Monitor 10's with RDO-194's. Vintage 1988 speakers. Would it be wise to JB Weld the drivers magnet for preventive maintenance while I have them out of service? I've searched for this info but yet to find. Thank You!
Yes, a great idea. -
Hey I have 2 MW6500's from my 7B's with shifted magnates that I would trade for 1 MW6500 that works. I attempted to do the whole jig thing but its been 3 days on and off and I haven't been able to get it lined up. If your interested in a swap like that, Im game!Post edited by mixscientist on
hello @lawdogg - do you have a 6511? thanks !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Hi @verb I just checked and unfortunately no I don't have any 6511s at the moment. Shoot!
my 3.1TLs
I will fix your shifted magnets for free. -
PM sent.
How is it working for you ?
i have i think 4-6 frozen SD 6600x from sda1 signature series.
wondering if you still do this, as i am going crazy trying to find replacements, because i dont feel confident to do this myself.
is it difficult? -
No, it's not really. Just have to get past the fear of separating the pole plate and magnet from the basket. Then find an appropriate sized PVC adapter and tap it for screws. I did a write up here somewhere....
is it difficult?
Very easy once you make the tool. Use a PVC pipe, cut an inch out of it all the way down to make it a collar, then use a hose clamp to clamp it onto the magnet. Use screws spaced evenly around the circumference to center the frame once it's in place.
A few more tricks but happy to explain in detail. Check out @FestYboy if he made a write-up. Good luck!my 3.1TLs
You happen to need any MW6502's? Had two polk's in my car labeled MMXIV which Tom at Polk service said is basically a MW6502....Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
I'm actually totally out of spares right now.
my 3.1TLs
Not worried about replacing them, just trying to keep them out of the landfill, cones are frozenComputer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Oh sorry, if you want to donate em to the cause, shoot me a PM!
my 3.1TLs
Is this still going?
Yes, sure is, but it has evolved from an exchange service to a repair service. There are a couple others who are offering the same service now too which is great!my 3.1TLs
