Wanted: Donations of Magnet-Shifted Drivers for my FREE Polk Driver Exchange service
  • teekay0007
    teekay0007 Posts: 2,289
    WasecaTech wrote: »
    I'm preparing to retweet Monitor 10's with RDO-194's. Vintage 1988 speakers. Would it be wise to JB Weld the drivers magnet for preventive maintenance while I have them out of service? I've searched for this info but yet to find. Thank You!
    Yes, a great idea.
  • mixscientist
    mixscientist Posts: 3
    edited January 2017
    Hey I have 2 MW6500's from my 7B's with shifted magnates that I would trade for 1 MW6500 that works. I attempted to do the whole jig thing but its been 3 days on and off and I haven't been able to get it lined up. If your interested in a swap like that, Im game!
    Post edited by mixscientist on
  • verb
    verb Posts: 10,176
    hello @lawdogg - do you have a 6511? thanks !!!
  • lawdogg
    lawdogg Posts: 469
    Hi @verb I just checked and unfortunately no I don't have any 6511s at the moment. Shoot!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • sslome
    sslome Posts: 5
    How is it working for you ?
    i have i think 4-6 frozen SD 6600x from sda1 signature series.
    wondering if you still do this, as i am going crazy trying to find replacements, because i dont feel confident to do this myself.
    is it difficult?
  • FestYboy
    FestYboy Posts: 3,861
    No, it's not really. Just have to get past the fear of separating the pole plate and magnet from the basket. Then find an appropriate sized PVC adapter and tap it for screws. I did a write up here somewhere....
  • lawdogg
    lawdogg Posts: 469
    sslome wrote: »
    is it difficult?
    Very easy once you make the tool. Use a PVC pipe, cut an inch out of it all the way down to make it a collar, then use a hose clamp to clamp it onto the magnet. Use screws spaced evenly around the circumference to center the frame once it's in place.
    A few more tricks but happy to explain in detail. Check out @FestYboy if he made a write-up. Good luck!
    <3 my 3.1TLs
  • starkiller
    starkiller Posts: 2,723
    You happen to need any MW6502's? Had two polk's in my car labeled MMXIV which Tom at Polk service said is basically a MW6502....
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • lawdogg
    lawdogg Posts: 469
    I'm actually totally out of spares right now. :(
    <3 my 3.1TLs
  • starkiller
    Not worried about replacing them, just trying to keep them out of the landfill, cones are frozen
  • lawdogg
    lawdogg Posts: 469
    Oh sorry, if you want to donate em to the cause, shoot me a PM!
    <3 my 3.1TLs
  • thoft
    thoft Posts: 1
    Is this still going?
  • lawdogg
    lawdogg Posts: 469
    thoft wrote: »
    Yes, sure is, but it has evolved from an exchange service to a repair service. There are a couple others who are offering the same service now too which is great!
    <3 my 3.1TLs
