LSiC and Denon/Audyssey
tlainhart
tlainhart Posts: 66
edited October 2006 in Speakers
I've got a LSi system (LSi7, LSiC, LSifx, and 250 SW), powered by a Denon 3806.
Regardless of how many times I run the AutoEQ for the Audyssey, Audyssey cuts the 250/500 EQ down to -20db, which makes the dialog on movies difficult to listen to. Ultimately I end up using manual EQ, and bypassing Audyssey. Anyone else have this problem?
A related question - when I listen to the test tones generated across the LS7s, the LSifxs and the LSiC, the LSiC sounds very muddy, like it has no top-end. It's wired in-phase, and I know that there's output from the tweeter. But it does behave as if the tweeter is out.
This is regardless if the speakers are set "large" or "small".
Thanks for any clues.
-- Todd
Post edited by tlainhart on
