Need help in picking out a ceiling fan
There seem to be a lot of stats on the larger fans and it's somewhat confusing. We are looking for a 3 blade large fan with dimmable lighting. Since it will be in the area where we listen to music I want something that is capable of moving a fair amount of air but do it with a minimal amount of noise. Anybody have a make/model that fits the bill?
Yep, my name really is Bob.
  • shawn474
    shawn474 Posts: 3,052
    edited March 2019
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
    pitdogg2 Posts: 27,293
    Why 3 blade ? Would a 5 blade move more air at a slower speed?
  • FestYboy
    FestYboy Posts: 3,861
    ^ more noise...
  • gmcman
    gmcman Posts: 1,859
    edited March 2019
    Generally ceiling fans with 5 blades have a different pitch on one or maybe more of the blades. IIRC, this reduces the noise.
    We have a 5-blade Hunter downstairs and on low it moves quite a bit of air and is practically silent.
    OTOH, my daughter wanted a table top fan for her room and didn't want to hear it. I agree with her about cheap table top fans that vibrate and make noise.
    I found a Rowenta 12" Silent night fan that you pretty much cannot hear from 8' away, the HVAC is louder. Best small fan I ever bought.
    Just a thought if you don't want to mount one, they also offer a 16" version now. They're pricey but on the lowest setting they are the quietest I've seen. A Vornado doesn't even remotely come close by comparison.
  • muncybob
    muncybob Posts: 3,266
    We like the look of 3 blade but if 5 blade moves more air with less noise then, that's the ticket.
    Yes my Hunter 5 blade moves massive air. I have not notices any pitch difference in the blades. In my experience the fans are much quieter than years past. I believe between the motors that have changed and the new suspension plates with rubber bumpers that have reduced a lot if the noise. A larger diameter reduces that need to run faster to move more air.
    FWIW
  • gmcman
    gmcman Posts: 1,859
    Most every fan I've owned, if you watch the blades, the edge of one will have a slightly higher track.
    mhardy6647 Posts: 35,224
    I will say that when it comes to ceiling fans, you definitely get what you pay for. If you want quiet & well balanced, go for a good one. My favorites are, apparently, no longer available, unfortunately.
    We still need one for our guest bedroom here... we had the room wired for one, but for reasons that escape me, we didn't actually have one put in there. Most other rooms in the house have 'em. The fans in this house are all Casablancas, but the model we used when this house was built (ca. 6 to 7 years ago now) is apparently NLA.
    11566772664_84645f410d_b.jpgDSC_5932 by Mark Hardy, on Flickr
    Hunters in the old house in MA.
    10839611305_f678e1d0bb_h.jpgDSC_7639 by Mark Hardy, on Flickr
    DSC_7739 by Mark Hardy, on Flickr
    VR3 Posts: 29,547
    edited March 2019
    I picked up one of these, liked it so much I bought one for each of the bedrooms.... No motor noise, dimmable led, remote controlled, moves tons of air... Solid wood blades, built well
    60"
    ^^^ nice looking fan.
  • muncybob
    .......what make/model is that?
    VR3 Posts: 29,547
    Am175led
  • muncybob
    In reading some reviews I'm concerned about the brightness of the light. It will be the closest light to my tt, bright enough to place/brush a record on the platter?
    VR3 Posts: 29,547
    I have quite literally 40 to 50 recessed cans all over my House so I don't use the light much, I actually liked it alot because of the small light.
    I will say that if it is your primary light, you may not be satisfied.
  • zingo
    zingo Posts: 11,258
    In my experience 3 blade fans make more noise. We have one in our bedroom and it's great, but I can hear each blade as it moves over my head.
    FYI, the less blades a fan has the more efficient it is because the motor works less and pushes against less air friction, but that doesn't mean quiet.
  • FestYboy
    Motor, bearing and blade design all have a factor on noise. Why they don't make a blade like an owl's wing (silent), I don't know.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Bruce ahem..... Let me know if you need the link
    Garage | Polk Monitor 5B's
    FestYboy wrote: »
    Because it would be a bear to clean the dust off of the blades. lol.
  • Mikey081057
    FestYboy wrote: »
    That's a hoot!
    edited March 2019
    FestYboy wrote: »
    That's a hoot!
    you guys are killin' me here...
