If Schitt were to commercialize a loudspeaker
mhardy6647
in Speakers
Perhaps this would be it?
The Schiit Loo?
Or maybe a joint venture with b&o (or maybe IKEA) called the Schiit Plümbing
source:
https://audiokarma.org/forums/index.php?threads/custom-tri-amplified-speakers-999-lexington-mi.860324/
In all seriousness, sort of a DIY version of the small Ohm "Walsh" (style) loudspeakers, it appears.
The Schiit Loo?
source:
They already have... It's called the Schiit Rol.
Wow. Gonna hafta read about that. Kinda reminded me of the SVS cylinder subs.
Aside - admit it Doc, you see a naked basket out in the open, and you just can't help yourself, can you?
I disabled signatures. -
Lol.. Is that an old water heater tank?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Schitt Horns
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
The Schitt show......"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
lol, I actually did, until just now, just assume this photo was taken in a laundry closet, and I wasn't even phased. I think I must just have thought it was for testing.I disabled signatures. -
Exactly, link says 18 inch pvc... Interesting- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Flies in the buttermilk, shoo, flies, shoo
Schiit in the loo, my darlin' -
Hey Doc, btw - did you finish that sub you were building?I disabled signatures.
You can put them in every room. The Schitt House.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
They have a new version for hospitals called the Schitt ER.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
That's a big 10-4... depending on one's definition of finish, of course.
Mine is -- it works.
It doesn't even have any clip leads any more. At least, I don't think it does...
DSC_0484 (2) by Mark Hardy, on FlickrFlies in the buttermilk, shoo, flies, shoo
This poetic side of you is one I haven't seen before -- obviously a warm-weather respite has been good for your soul
In total seriousness (well, you know...), there is much to be said for the application of pipes to loudspeaker enclosure design. The DCM timewindows were constructed (in part) from Sonotube, as, of course, were Nelson Pass' remarkable El-Pipe-o subwoofers.
The full range driver craze of the late 1990s early 2000s had a sect that was invested in PVC pipe enclosure designs, in turn either sensible or hallucinatory.
Google search PVC pipe speaker enclosure (or the like) and you'll see some. I actually haven't managed to find the specific one I am thinking of from Jamie Melhuish's Full Range Driver Site of yore.
Post edited by mhardy6647 on
