If Schitt were to commercialize a loudspeaker
mhardy6647
mhardy6647 Posts: 35,184
Perhaps this would be it?
The Schiit Loo?
Or maybe a joint venture with b&o (or maybe IKEA) called the Schiit Plümbing
source:
https://audiokarma.org/forums/index.php?threads/custom-tri-amplified-speakers-999-lexington-mi.860324/
In all seriousness, sort of a DIY version of the small Ohm "Walsh" (style) loudspeakers, it appears.
    nooshinjohn Posts: 25,973
    They already have... It's called the Schiit Rol.
    msg Posts: 10,452
    Wow. Gonna hafta read about that. Kinda reminded me of the SVS cylinder subs.
    Aside - admit it Doc, you see a naked basket out in the open, and you just can't help yourself, can you? :D:D
    VR3 Posts: 29,520
    Lol.. Is that an old water heater tank?
  • Mikey081057
    Mikey081057 Posts: 7,127
    Schitt Horns
    Garage | Polk Monitor 5B's
    EndersShadow Posts: 17,715
    The Schitt show......
    msg Posts: 10,452
    VR3 wrote: »
    lol, I actually did, until just now, just assume this photo was taken in a laundry closet, and I wasn't even phased. I think I must just have thought it was for testing.
    VR3 Posts: 29,520
    Exactly, link says 18 inch pvc... Interesting
  • tonyp063
    tonyp063 Posts: 1,135
    Flies in the buttermilk, shoo, flies, shoo
    Schiit in the loo, my darlin'
    msg Posts: 10,452
    Hey Doc, btw - did you finish that sub you were building?
  • nspindel
    nspindel Posts: 5,343
    You can put them in every room. The Schitt House.
    They have a new version for hospitals called the Schitt ER.
    edited March 2019
    msg wrote: »
    That's a big 10-4... depending on one's definition of finish, of course.
    Mine is -- it works.
    It doesn't even have any clip leads any more. At least, I don't think it does...
    39959755992_b83e2af943_h.jpgDSC_0484 (2) by Mark Hardy, on Flickr
    tonyp063 wrote: »
    This poetic side of you is one I haven't seen before -- obviously a warm-weather respite has been good for your soul :)
    In total seriousness (well, you know...), there is much to be said for the application of pipes to loudspeaker enclosure design. The DCM timewindows were constructed (in part) from Sonotube, as, of course, were Nelson Pass' remarkable El-Pipe-o subwoofers.
    The full range driver craze of the late 1990s early 2000s had a sect that was invested in PVC pipe enclosure designs, in turn either sensible or hallucinatory.
    Google search PVC pipe speaker enclosure (or the like) and you'll see some. I actually haven't managed to find the specific one I am thinking of from Jamie Melhuish's Full Range Driver Site of yore. :#
    Post edited by mhardy6647 on
