Lumin U1 Mini
    tonyb Posts: 33,069
    Good points, but different applications. There is also data collecting going on, so I can see where they don't want older versions that may not support the data collecting running on newer gear.
    Not a big deal for me, but it becomes one when sound quality or functionality are affected. That's my main gripe with updates.
    On another note....
    Now that we have multiple higher end streamers out on the market for some time now, I've heard the differences as has many others. The tired old theory of 1's and 0's being the same has finally been put to rest.
    Back on topic...
    The Lumin mini,
    I'd be very interested to hear about experiences with this unit. The standard Lumin I've heard tell can be a bit sterile sounding, any truth to that ?
    For me anyway, the crux of the matter with streamers is to find one that's more musical, rather than a detail retrieving champ. Has a good app too or separate controller.
  • Mikey081057
    Mikey081057 Posts: 7,127
    So the U1 Mini will probably sound different depending on the dac and everything else it is paired with downstream.
    In my rig i have:
    U1 Mini via dig coax to spdif of Brooklyn DAC+ balanced out to a Parasound P5 to a Parasound A21 to a pair of Usher mini dancer X dmd's and a SVS SB4000 sub.
    Very musical and very quiet. Too me the sound stage is deeper... which is an attribute of the Ushers but is enhanced by the U1 Mini.
    Detail is nice but not overly analytic... not distracting. Vocals feel more organic. Instruments like the sax and acoustic instruments sound more dynamic. A saxophone can naturally be very dynamic.... and they sound more real now.
    I have always had an illusion that somehow my center channel was playing in this rig and early on had actually got up to check and see that it wasn't. I hear a drummer in the back... vocals in front and instruments placed left and right of them. The 2 channels in this rig produce a deep and mesmerizing sound stage that makes me not miss my cd/sacd. Now I haven't interconnected my UDP 203 in yet but that will be interesting to compare.
    Garage | Polk Monitor 5B's
  • Mikey081057
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Your Ushers on the matching stands look awesome, I'd like to try a pair in my setup one day. Of course, the rest of your Stereo looks great as well!
    tonyb Posts: 33,069
    Skip, were you using the Lumin at Lonestar last year ?
  • erniejade
    erniejade Posts: 6,321
    About a year ago, my Lumin D1 had a strange issue with one of the updates. On computer audiophile ( they changed their name recently) I got a hold of Wilkie and he walked me through putting the old firmware via a usb stick back onto the D1 until the newer firmware was fixed. Wilkie is usually quick to respond to questions or issues on this lumin thread in https://audiophilestyle.com/forums/topic/14016-lumin-audiophile-network-music-player/page/72/
    I do not find the D1 sterile at all. I have tried it against the KEF internal dac, LH Labs VI dac and I prefer the D1. The D1 had more bloom to it, wider soundstage, more solid bass vs the kef's built in wifi dac and the VI.
    I have not heard the lumin U1 but, I believe it is a wired streamer only correct? Or did they add wireless to the U1?
  • Mikey081057
    wired only correct.
  • Mikey081057
    Been experimenting with the Lumin App...
    It seems to me unless someone can tell me other wise that the Lumin App does not show what's playing if it was launched from roon and vice versa. BluOS did do that.
    The app is ok,,, I prefer roon as it is second nature to me at this point.
  • erniejade
    I don't think the the lumin app can tell you what's playing if launched from roon. Although i haven't used roon so there might be an answer to this.
    If your not on computer audiophile, join up and post in that thread i put above. Wilkie is actually one of Lumin's engineers.
  • mark090852
    mark090852 Posts: 998
    erniejade wrote: »
    He is also on the Audioshark Forum, and has been very responsive to LUMIN questions posted there.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • erniejade
    Agreed @mark090852. On either forum, he has been very helpful from MiniMserver on down to how to type stuff.
  • Mikey081057
    I have seen and read him on Audioshark.
    I posted on Audiophile Style....
  • GlennDog
    GlennDog Posts: 3,150
    Very musical and very quiet. To me the sound stage is deeper... which is an attribute of the Ushers but is enhanced by the U1 Mini.
    Mikey, you just about sold me at ^^^ that ^^^ description
    Can we/I get an update on the mini?
    Did you try it with OPPO?
    What type and make of cable are you using Out of mini to your DAC+
    I’m an iOS guy and was toying with the G1, deeper digging has me leaning toward the Mini
    Any pros/cons come to mind? I’m thinking of dipping my toe in . . . Thanks, man!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    DSkip wrote: »
    It sounds like this avenue would finally put that Platinum Starlight to good use!
    Sold it to Verb for a cool hundie . . . NOT!
    Thanks for the input, Skip
    Yeah, kinda excited whichever direction I go in
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • Mikey081057
    So the Lumin U1 Mini has performed flawlessly. I have it connected to my Brooklyn DAC+ with a Wireworld Micro-Silver Eclipse 8 AES/EBU cable. The DAC feeds in analog to my PSAudio Stellar Gain DAC/PRE.
    I use the Oppo as a SACD player into the PSAudio SGD. I modded the OPPO 203 with an I2S interface upgrade...
    Net results are very satisfying...very quiet with a deep/wide soundstage that was a nice upgrade over my previous trials of computer and streamer setups.
    I don't use the Lumin app as I use ROON and I am very pleased with the flexibility of the app and ease of use.
  • GlennDog
    edited July 2019
    Mikey . . . Thank you, Sir!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • Mikey081057
    Go for it!!
  • GlennDog
    edited July 2019
    Go for it!!
    Skip musta broke his dial'n finger
    WOW, just dated the sizzle out me!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • jdjohn
    jdjohn Posts: 3,329
    Or maybe an Alexandra that just says idiotic drivel
    :D
    Mikey, have you tried the Lumin U1 Mini directly into the PSA SGC DAC/pre...letting the PSA do the conversion? Asking for a friend ;)
  • Mikey081057
    I have not... I really have the Brooklyn DAC+ dialed in... I do think it would be good but wouldn't expect that the PSA DAC would deliver any better SQ but it would still be good. The Brooklyn DAC+ also serves as my phono pre and it does a surprisingly good job of that too.
    If you are in the area and want to do an A/B test I will supply the beverages
  • jdjohn
    jdjohn Posts: 3,329
    Thanks for the offer! Sadly, I think the distance is too great...I'm in Nashville.
  • CottageChz
    CottageChz Posts: 416
    Damn man, just wanted to say, that is a helluva system! Tons of awesome gear and a really clean looking setup. Was just searching for feedback on Lumin products on here and happened to come across this pic. Good feedback on the U1 on this thread too, and Roon vs Lumin app...
  • WagnerRC
    WagnerRC Posts: 2,200
    Very clean looking set up. Congrats
    tonyb Posts: 33,069
    I duuno Mickey, love the system but one thing sticks out as falling short.....that screen is too small bro. :)
  • Mikey081057
    Dude that's just the screen in that room...Basically used as a computer monitor. The HT has a 75" LOL
