Bottlehead Crack Sale from 3/1 to 3/8.
ALL212
in Headphones
$100 off the kit and $25 off the Speedball. Not on the website yet but should be on Friday.
Aaron
Enabler Extraordinaire
Good price. Been thinking about getting back into DIY and building this kit as a start. But my headphones were low impedance. Karma’d the Schiit amp and sold the headphones here. So what headphones are a good match for the Crack?
Sennheiser 600, 650's... Massdrop had the Senn 6xx's and heck...another set also for good pricing.
Anything above 200 ohm.Aaron
Enabler Extraordinaire -
Thanks.
Humm Maybe I finally pull the trigger on one..
Mine is still sitting in its box from probably a year ago.
I figure by some miracle of entropy, it will be completed if I wait long enough to open it.
My 6XX are ready for that day...Jay
@agfrost - send it! I'll build it for you.Aaron
Thanks Aaron--I'm willing and (I believe able); I first was thinking about if I wanted to do more than stock build at first (better volume pot, e.g.) and that slowed me down. I think I'd rather go mild at first (wild later?) so perhaps I'll heat up the iron over Spring Break coming up...Jay
Better volume pot is a good idea and not difficult nor expensive (unless you choose to make it expensive).
BH crew always recommends building stock, then going crazy. It's really not a bad idea.
When you get to your crazy stage let me know - I've got some GREAT! ideas.
And, yes, I did order one. I have plans...Aaron
With the Speedball?
Yep...wid da spudballer.
Speedball allows use of more tube variants without modification to other parts. Doesn't mean you can go crazy but it opens up the options a bit.Aaron
...off topic (but it feels like just you and me in here at the moment), but I just picked up a Little Dot Mk ii to play with until I get to building.
My "unofficial" hp amp collection is getting laughably large--Schitt Asgard and Vali 2; LD MKii, a little Fiio DAC/amp thingy... Might have the beginnings of a problem. (Not as big as *your* problem, but...)
Jay
Got a fav? I'm a bit one sided with my BH/Senn collection. Not much perspective outside of that.Aaron
I like the Senn 600's (300 ohm) and (my fave) Beyer DT-990 (600 ohm; "Premium", I think?). I never upgraded anything and still use the stock tubes. Never felt the need or desire to change anything. Love the thing even though I don't use it too frequently.
Craig
