Bottlehead Crack Sale from 3/1 to 3/8.
ALL212
ALL212 Posts: 1,664
$100 off the kit and $25 off the Speedball. Not on the website yet but should be on Friday.
Aaron
Enabler Extraordinaire
  • maxward
    maxward Posts: 1,718
    Good price. Been thinking about getting back into DIY and building this kit as a start. But my headphones were low impedance. Karma’d the Schiit amp and sold the headphones here. So what headphones are a good match for the Crack?
  • ALL212
    ALL212 Posts: 1,664
    Sennheiser 600, 650's... Massdrop had the Senn 6xx's and heck...another set also for good pricing.
    Anything above 200 ohm.
    Aaron
    Toolfan66 Posts: 18,169
    Humm Maybe I finally pull the trigger on one..
  • agfrost
    agfrost Posts: 2,474
    Mine is still sitting in its box from probably a year ago.
    I figure by some miracle of entropy, it will be completed if I wait long enough to open it.
    My 6XX are ready for that day...
    Jay
  • ALL212
    ALL212 Posts: 1,664
    @agfrost - send it! I'll build it for you.
    Aaron
  • agfrost
    ALL212 wrote: »
    Thanks Aaron--I'm willing and (I believe able); I first was thinking about if I wanted to do more than stock build at first (better volume pot, e.g.) and that slowed me down. I think I'd rather go mild at first (wild later?) so perhaps I'll heat up the iron over Spring Break coming up...
    Jay
  • ALL212
    ALL212 Posts: 1,664
    Better volume pot is a good idea and not difficult nor expensive (unless you choose to make it expensive).
    BH crew always recommends building stock, then going crazy. It's really not a bad idea.
    When you get to your crazy stage let me know - I've got some GREAT! ideas.
    And, yes, I did order one. I have plans...
    Aaron
  • maxward
    With the Speedball?
  • ALL212
    ALL212 Posts: 1,664
    Yep...wid da spudballer.
    Speedball allows use of more tube variants without modification to other parts. Doesn't mean you can go crazy but it opens up the options a bit.
    Aaron
  • agfrost
    ...off topic (but it feels like just you and me in here at the moment), but I just picked up a Little Dot Mk ii to play with until I get to building.
    My "unofficial" hp amp collection is getting laughably large--Schitt Asgard and Vali 2; LD MKii, a little Fiio DAC/amp thingy... Might have the beginnings of a problem. (Not as big as *your* problem, but...)
    Jay
  • ALL212
    ALL212 Posts: 1,664
    Got a fav? I'm a bit one sided with my BH/Senn collection. Not much perspective outside of that.
    Aaron
  • vcwatkins
    vcwatkins Posts: 1,992
    I like the Senn 600's (300 ohm) and (my fave) Beyer DT-990 (600 ohm; "Premium", I think?). I never upgraded anything and still use the stock tubes. Never felt the need or desire to change anything. Love the thing even though I don't use it too frequently.
    Craig
