broken speakers need help
Hi, I am new here and looking to get some help. I have 2 pair of monitor 40 and 1 of them were broken and need to know how can I fix it. The front panel were the speakers and tweeter are mounted, the entire frame fall out from the box itself and there are some cracks on some of the coners, I can put back inside but i do not know if there is something i can do to fix it. thanks in advance
    F1nut Posts: 52,018
    Some pictures would be helpful.
    F1nut Posts: 52,018
    I take it the speaker was dropped.
    The front bezel was glued in place originally. You can use Liquid Nails or any construction adhesive to glue it back on.
  • hcch
    hcch Posts: 3
    thanks for the recomendation, I did hooked up and seems to be sounding just fine. It is a shame the speaker was perfect
