Marantz NR1608.....pre-out
Hello
I was looking at the NR1608 manual, trying to find out how to use the pre-out for main front speakers, but it's not very clear
Can I use an external amp to power the front mains, and leave the receiver handle other speakers (center, front heights and surrounds)?
I can't find it in the manual........
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
  • Hermitism
    Hermitism Posts: 4,333
    mdaudioguy wrote: »
    Yes, I do exactly that.
    Welcome back! You missed me, didn't you?
  • rooftop59
    rooftop59 Posts: 8,120
    French_guy wrote: »
    Hello
    Yep just run a pair of rca cables from the pre outs to the amp, then connect the speaker cable for the mains to the amp. Make sure amp is on and run audyssey. Proceed as usual!
    Game Room 5.1.4:
    Bedroom 2.1
  • I've been posting several times about a new receiver for my RTia5 and CSia4......
    I have now a 75" 4k TV, and was finally able to sell (just this morning) my old Pioneer VSX 920 receiver ($100...I think it was a good price)
    Now, I really need to pull the trigger on a new receiver !
    Still not sure which one to get though.....looking for the best quality/price compromise I guess
    No surround...yet
  • mdaudioguy wrote: »
    How do you like your NR1608?
    No surround...yet
    F1nut Posts: 51,956
  • rooftop59
    French_guy wrote: »
    I would grab the SR5012 in accessories4less if that's where you are looking. Or the DENON AVR-X3400H. I had a Marantz NR for awhile in the bedroom rig, and while its great for what it is, moving up to the SR was a clear step up in sound quality.
    Of all the AVRs I've owned (and I have owned a lot), the Denon AVR-X4200w I am currently running in the living room is my fav, but marantz and yamaha also make really good AVRs. Basically find one that has the features you want/need, and preouts, and you should be golden.
    Game Room 5.1.4:
    Bedroom 2.1
  • JayMX
    JayMX Posts: 459
    I love my NR1607 feeding pre-out to the ol 1060 using the L/R bypass and Direct settings for stereo listening. Works very well. I have tried feeding both the aux input and directly into the power amp of the 1060. I prefer the aux input and having a little more gain and tone controls to warm things up. Good stuff! x1vzf9uqlk1k.jpeg
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    French_guy wrote: »
    mdaudioguy wrote: »
    Does precisely what I wanted/needed - allows for a separate amp to drive my main speakers, while handling the other three quite easily, and is slim enough to fit in my cabinet.
  • mdaudioguy
    JayMX wrote: »
    I like that modern/retro combo!
  • mdaudioguy
    Howdy back at you, Jesse. B)
