Marantz NR1608.....pre-out
French_guy
in Electronics
Hello
I was looking at the NR1608 manual, trying to find out how to use the pre-out for main front speakers, but it's not very clear
Can I use an external amp to power the front mains, and leave the receiver handle other speakers (center, front heights and surrounds)?
I can't find it in the manual........
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
No surround...yet
Yes, I do exactly that.
https://forum.polkaudio.com/discussion/182995/hybrid-system-follow-up -
Welcome back! You missed me, didn't you?mdaudioguy wrote: »Yes, I do exactly that. -
French_guy wrote: »Hello
Yep just run a pair of rca cables from the pre outs to the amp, then connect the speaker cable for the mains to the amp. Make sure amp is on and run audyssey. Proceed as usual!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I've been posting several times about a new receiver for my RTia5 and CSia4......
I have now a 75" 4k TV, and was finally able to sell (just this morning) my old Pioneer VSX 920 receiver ($100...I think it was a good price)
Now, I really need to pull the trigger on a new receiver !
Still not sure which one to get though.....looking for the best quality/price compromise I guess
No surround...yet -
How do you like your NR1608?RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
Howdy Ed.Political Correctness'.........defined
President of Club Polk -
French_guy wrote: »I've been posting several times about a new receiver for my RTia5 and CSia4......
I would grab the SR5012 in accessories4less if that's where you are looking. Or the DENON AVR-X3400H. I had a Marantz NR for awhile in the bedroom rig, and while its great for what it is, moving up to the SR was a clear step up in sound quality.
Of all the AVRs I've owned (and I have owned a lot), the Denon AVR-X4200w I am currently running in the living room is my fav, but marantz and yamaha also make really good AVRs. Basically find one that has the features you want/need, and preouts, and you should be golden.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I love my NR1607 feeding pre-out to the ol 1060 using the L/R bypass and Direct settings for stereo listening. Works very well. I have tried feeding both the aux input and directly into the power amp of the 1060. I prefer the aux input and having a little more gain and tone controls to warm things up. Good stuff!
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩 -
Does precisely what I wanted/needed - allows for a separate amp to drive my main speakers, while handling the other three quite easily, and is slim enough to fit in my cabinet.French_guy wrote: »mdaudioguy wrote: »Yes, I do exactly that.
How do you like your NR1608? -
I like that modern/retro combo! -
Howdy Ed.
Howdy back at you, Jesse.
