Damn Protected CDs!!!
glemay
glemay Posts: 574
edited January 2005 in Music & Movies
Now this pisses me off. I just bought a new CD and wanted to put it on my computer so that I can put it on my new MP3 Player and I can't because the damn thing is protected! When copied to the computer if it even works there are pops and clicks. Anyone know a way around this? I can't do anything with the damn CD, the only way to listen to it is on a CD player, no computer and no MP3 player. Here is a link I found.
link
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited December 2004
    you can record it in analog then convert that wav file to mp3.
  • wallstreet
    wallstreet Posts: 1,405
    take it back and ask for your money back. Explain to them your primary listening hardware is a computer.
  • glemay
    glemay Posts: 574
    How do I record it in analog then convert the .wav file to .mp3?
    Main System:
    Second System:
  • tryrrthg
    You have to connect the line out of your computer with the line in then use a program like Windows sound recorder. You'll have to play each song (as if you were listening to it) as it's recording, it takes a LONG time but it should get you what you want...
    converting from wav to mp3 can be done on programs like Music Match, at least it used to, I don't know if it does anymore...
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    there's a system file you can download or a registry hack you can do to force windows to "see" the actualy wav files on the CD, so that you can just drag and drop them like any other files, then convert to mp3 later.
    I don't remember what it's called, but it does exist...search around on Google...
    EDIT: I think it's a dll file that you add...starts with a v maybe?
    VR3 Posts: 29,534
    There was a trick u could do with a felt tip marker...
    However I wouldnt do it! ;)
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    So, care to share what CD and the label?
  • glemay
    glemay Posts: 574
    velvet revolver - contraband
    I think BMG records
    Main System:
    Second System:
  • Demiurge
    Demiurge Posts: 10,874
    I think BMG records
    Ohhh...the sweet irony!!!! :eek: :D:D:p:D:D :eek:
  • glemay
    glemay Posts: 574
    what is so ironic, i don't get it
    Main System:
    Second System:
  • Demiurge
    F1nut Posts: 51,944
    As it should be, IMHO.
  • Toxis
    Toxis Posts: 5,116
    I had a CD like this so I contacted the recording company and told them I wanted to take the cd and put it on MY iPod, not for resale and I am the rightful owner of the disk. They then sent me a link to a website where I could d/l all the songs in a format my iPod could play. Worked for me...
  • Loud & Clear
    Loud & Clear Posts: 1,538
    Agreed, but it's nice to be able to rip to .wav (lossless, I believe) and then burn for backup and compilation's sake. Does that make sense?
    Also, I haven't purchased a CD that I haven't been able to rip to .wav.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • ntculenuff
    ntculenuff Posts: 1,146
    i have this cd and the same thing man it made me mad cant even listen to it on my pc. so now i just turn up my big stereo louder so that i can hear it in the pc room
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • fireshoes
    fireshoes Posts: 3,167
    I remember reading at one point that if you hold down a button when you load the cd, it bypasses the anticopy stuff. I think you hold control. Haven't tried it.
  • sowen010599
    sowen010599 Posts: 343
    When you FIRST insert ANY new CD, press and hold SHIFT. That will stop any copy protection software or driver from being installed. Rip to your heart's content.
    Go BIG or go home!
  • glemay
    glemay Posts: 574
    edited January 2005
    don't work
    Main System:
    Second System:
  • sowen010599
    edited January 2005
    hehe, not now!
    If you missed it the first time, you have to locate and remove the offending process or driver.
    What CD was it? For instance, Velvet Revolver installs SunnComm's Media Max. It would have to be removed before you could do anything.
    Go BIG or go home!
  • glemay
    glemay Posts: 574
    edited January 2005
    where do i find the file?
    Main System:
    Second System:
  • avelanchefan
    avelanchefan Posts: 2,401
    edited January 2005
    Glemay, after searching the internet i found that you can use a multiple of programs to rip copy protected CD's, anything from Windows Media 10. (Have you tried that?) to Nero.
    Nero is a legit program that is installed with almost all DVD/CD RW drives anymore.
    If you can enable your PM or just email me at avelanchefan@yahoo.com, I can help you more.
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
  • glemay
    glemay Posts: 574
    edited January 2005
    ok i enabled my pm but not sure how it works avalanchefan
    Main System:
    Second System:
  • glemay
    glemay Posts: 574
    edited January 2005
    well so far I got it copied to my harddrive but when I try to play it on my mp3 player it won't play, it just skips the track.
    Main System:
    Second System:
  • avelanchefan
    edited January 2005
    PM has been sent to you Glen.
    Sean
    PSN---->Floppa
