Damn Protected CDs!!!
glemay
Now this pisses me off. I just bought a new CD and wanted to put it on my computer so that I can put it on my new MP3 Player and I can't because the damn thing is protected! When copied to the computer if it even works there are pops and clicks. Anyone know a way around this? I can't do anything with the damn CD, the only way to listen to it is on a CD player, no computer and no MP3 player. Here is a link I found.
link
link
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
you can record it in analog then convert that wav file to mp3.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
take it back and ask for your money back. Explain to them your primary listening hardware is a computer.
How do I record it in analog then convert the .wav file to .mp3?Main System:
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
You have to connect the line out of your computer with the line in then use a program like Windows sound recorder. You'll have to play each song (as if you were listening to it) as it's recording, it takes a LONG time but it should get you what you want...Originally posted by glemay
converting from wav to mp3 can be done on programs like Music Match, at least it used to, I don't know if it does anymore...
Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
there's a system file you can download or a registry hack you can do to force windows to "see" the actualy wav files on the CD, so that you can just drag and drop them like any other files, then convert to mp3 later.
I don't remember what it's called, but it does exist...search around on Google...
EDIT: I think it's a dll file that you add...starts with a v maybe? -
There was a trick u could do with a felt tip marker...
However I wouldnt do it!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So, care to share what CD and the label?
velvet revolver - contraband
I think BMG recordsMain System:
Second System:
I think BMG records
Ohhh...the sweet irony!!!! :eek:
:eek: -
what is so ironic, i don't get itMain System:
Second System:
As it should be, IMHO.Political Correctness'.........defined
President of Club Polk -
I had a CD like this so I contacted the recording company and told them I wanted to take the cd and put it on MY iPod, not for resale and I am the rightful owner of the disk. They then sent me a link to a website where I could d/l all the songs in a format my iPod could play. Worked for me...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Agreed, but it's nice to be able to rip to .wav (lossless, I believe) and then burn for backup and compilation's sake. Does that make sense?
Also, I haven't purchased a CD that I haven't been able to rip to .wav.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
i have this cd and the same thing man it made me mad cant even listen to it on my pc. so now i just turn up my big stereo louder so that i can hear it in the pc roomSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
I remember reading at one point that if you hold down a button when you load the cd, it bypasses the anticopy stuff. I think you hold control. Haven't tried it.
When you FIRST insert ANY new CD, press and hold SHIFT. That will stop any copy protection software or driver from being installed. Rip to your heart's content.Go BIG or go home!
don't workMain System:
Second System:
hehe, not now!
If you missed it the first time, you have to locate and remove the offending process or driver.
What CD was it? For instance, Velvet Revolver installs SunnComm's Media Max. It would have to be removed before you could do anything.Go BIG or go home! -
where do i find the file?Main System:
Second System:
Glemay, after searching the internet i found that you can use a multiple of programs to rip copy protected CD's, anything from Windows Media 10. (Have you tried that?) to Nero.
Nero is a legit program that is installed with almost all DVD/CD RW drives anymore.
If you can enable your PM or just email me at avelanchefan@yahoo.com, I can help you more. -
ok i enabled my pm but not sure how it works avalanchefanMain System:
Second System:
well so far I got it copied to my harddrive but when I try to play it on my mp3 player it won't play, it just skips the track.Main System:
Second System:
PM has been sent to you Glen.
