Looking for New DAC
So story short my TEAC UD-301 pass out. Main board got rusted my best guess humidity got into it. Not sure why the area here is not that humid and all other components are fine after a check (amp, pre and player). All of this is in the output section of the DAC. I contacted TEAC about buying a new main board. No reply so far.
I am considering getting the Marantz HD-DAC1 or Musical Fidelity MX DAC. Any comments?
Or
I will still try to repair the 301 and I will find the board.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • afterburnt
    afterburnt Posts: 7,892
    híjole! is that the Titanic?
  • afterburnt
    DSkip wrote: »
    I wish I still had some Intenso in stock as it'd be a knock out winner over the HD-DAC1 which is my second favorite three figure DAC. I do have a Blue Diamond CD Player priced well below MSRP that could be your full digital solution, but still about twice your budget.
    I haven't announced it publicly, but my partnership with North Star is coming to a close. Unlike Dayens, NSD has been flawless and I truly wish I didn't have to take this route. If you can find some of their DAC's, they are particularly difficult to beat in the more budget-friendly arena.
    That totally blows! I wish I had room for an upgrade NS is the shciznit!
  • verb
    verb Posts: 10,176
    DSkip wrote: »
    Agree with Skip! I have the Intenso which is in the main rig, and I have an AMP-1 which has I believe has the same DAC, but I needed an integrated for the office rig.
  • Joey_V
    Joey_V Posts: 8,505
    Musics fidelity makes nice DACs
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • BlueFox
    BlueFox Posts: 15,251
    Bryston makes a great DAC. While it has a four figure price, it is worth it.
    http://www.bryston.com/products/digital_audio/BDA-3.html
  • zingo
    zingo Posts: 11,256
    I love my NuForce WDC200 for it’s ability to handle lossless media over wifi.
    Clipdat Posts: 12,559
    I'm not sure that is rust in the photos, but possibly just electrical circuit damage.
  • displayname
    displayname Posts: 1,126
    DSkip wrote: »
    That's a bummer to hear that Skip. They had good stuff from what I heard. Are you on the hunt for something new in that price point, or possibly leaning on Norma for the digital front moving forward?
    Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
    Discogs
  • WagnerRC
    WagnerRC Posts: 2,138
    Joey_V wrote: »
    I have an M1 dac in black sitting here in the closet. If anyone is looking.
  • Mikey081057
    Mikey081057 Posts: 7,127
    https://mytekdigital.com/hifi/
    I have a Brooklyn DAC+ and love it.
    Garage | Polk Monitor 5B's
  • Irrenhaus
    Irrenhaus Posts: 1,082
    edited March 2019
    Hi
    Thanks for the advice. Have not updated yet. Work has been very busy and add jury duty to the mix. Probably will go with the Marantz like the headphone amp feature will go well with My HD650.
    Cheers
  • Irrenhaus
    DSkip wrote: »
    Get the Excelsio in the FM. It will trounce anything under four figures and is a steal at the price.
    Thanks for the recommendation but that one is gone. I am still looking been busy at work. This ones are also on the list.
    Yulong DA9 only draw back no remote.
    http://www.yulongaudio.com/pd.jsp?id=29#_pp=2_733
    Burson Audio Playmate Everest
    https://www.bursonaudio.com/products/playmate/
    RME ADI-2 DAC
    http://www.rme-audio.de/en/products/adi_2-dac.php
    I will be in Japan next week and will be staying in the electronic district (Akihabara) not sure if I want to bring back something from there. Not sure how much I will have to pay at customs.
    Cheers
  • BlueFox
    Get the Lumin X1, which is a file player and DAC. I have the S1, and will soon be upgrading to the X1. However, I recently upgraded the S1 power supply to the X1 power supply, and have been so happy I am in no rush to get the X1, but eventually I will.
    A big benefit of the integrated DAC in the Lumin is you do not need to buy a DAC power cord, and interconnect cables. That saves at least $6K right there over having an external DAC.
  • kharp1
    kharp1 Posts: 3,453
    The Marantz SA14 I have in the FM is a top notch SACD player and a pretty good DAC.
  • verb
    verb Posts: 10,176
    Irrenhaus wrote: »
    DSkip wrote: »
    Cheers
    Sorry my friend as I snagged the NS and love it! :smile:
    Hey the native stuff in Japan, aren’t they different in power requirements? 100v and 220v depending on the region, IIRC.
  • Irrenhaus
    BlueFox wrote: »
    That one is out of budget.
    Cheers
  • Irrenhaus
    kharp1 wrote: »
    I already have a SA8005 using as a DAC till I get something else.
  • Irrenhaus
    Well the Pioneer was not available new. Only floor samples and no boxes.
    No time to get boxes to take it home. Well I will be back next month.
    Cheers
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,066
    That is some "CANDY" store.
    Harry / Marietta GA
  • Irrenhaus
    Okay so I kind of taken a different route on this one. I just pulled the trigger on the Schiit Jotunheim with no DAC. I have been using the DAC on the SA8005 and has been working great and I will like to able to better power my headphones. (650, Meze Noir and Marshall's)
    https://www.schiit.com/products/jotunheim
    I will still be looking for a separate DAC in the future, maybe one with balance outputs.
    Once it's get here I will start another thread on the Headphone section.
    Cheers
    nooshinjohn Posts: 25,034
    Take a look at PS Audio... I have been in love with my digital side since I got a PerfectWave MkII.
  • Irrenhaus
    This seems to be a nice DAC.
    http://www.audio-gd.com/R2R/R1/R1EN.htm
    After seeing pictures of the inside, I had doubts about the transformer as well.
  • machone
    machone Posts: 1,471
    Mojo Audio uses R2R in their DACs. I love my V2. Built like a tank.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • BlueFox
    edited May 2019
    I love the built in DAC of my Lumin X1. Plus I saved $6K by not having to buy a power cable, and interconnect cables to it. :)
  • Irrenhaus
    Clipdat wrote: »
    Thanks. I have been also looking at the one.
    PS Audio PerfectWave DAC MkII can be had for around 1200 bucks. It can also be upgraded to DirectStream. I love mine...
