Subwoofer wiring w/o cables
grozsa
grozsa Posts: 1
I am trying to hook up a PSW202 to an older Sony reciever that does not have a subwoofer out connection. I have hooked the speaker inputs on the PSW2020 to the same terminals that handle the main speakers outs on the reciever. Is this right? Alternatively, can I run the tape monitor outs RCA connectors through a Y cable to the PSW202? Which is prefereable?
Post edited by grozsa on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited December 2004
    Welcome to the Polk forum.
    The way you have it hooked up is fine. You can try your other suggestion, but I think you will have better results from the speaker level inputs. Hope this helps. Enjoy your new sub.
    Zach
    Tschüss
    Zach
  • John K.
    John K. Posts: 822
    Groz, as Zach indicated, with your present receiver that speaker wire connection to transmit the signals(essentially zero power is used)is the best that you can do. It wouldn't be a good idea to use the tape monitor outputs since the volume control on your receiver doesn't vary the tape monitor output and every time that you changed the volume level the sub level would stay the same unless you manually changed it.
  • dorokusai
    dorokusai Posts: 25,576
    I concur with the other individuals.....use the speaker level input method for your application.
