Usher S-525
daboyz
Beautiful center speaker. Going different direction so no longer needed. It's big and heavy. I have original box.
$200 shipped CONUS. PayPal gift please.
The S-525 Center Channel is the perfect accompaniment to the S-520 mini-monitors. It shares the same polypropylene woofers, soft dome tweeter and high-quality finish options. Just like its sister speakers, the S-525 is constructed of thick MDF, covered with a solid wood veneer and protected with several layers of clear coat. It is also a perfect match in both tone and timbre. Features include twin-tuned ports, two 5-inch woofers, four solid brass speaker terminals for bi-wiring and bi-amping and standard jumpers.
Specifications:
S-525
2-way system: tweeter 1" (UA025C-10), mid-bass 5" (5201W)
sensitivity: 90 dB @ 1 watt / 1m
nominal impedance: 4 ohms
frequency response (-3 dB): 48 Hz ~ 20 kHz
power handling: 80 watts
crossover frequencies: 2.38 kHz
weight: 12 kgs
dimensions (w x d x h): 60 cm x 30.5 cm x 18 cm -
Looks a lot like a Vienna Acoustics center. Looks nice!
If I wouldn't have just ordered the S35 I would have tried this baby out."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
$175 shipped. Lowest I will go.
Bump
Will this play well with my 6361s?
I had it with the 6311's and thought it was just peachy. YMMV
@daboyz If it aint been rode hard and put up wet, and if YMMV ain't something satanic I will take it for $175, after all, it's not like I never been BOHICA'd before.
Your mileage may vary...
Looks like a sweet center!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@daboyz you were reading my mind, sorry. PM sent
Done deal?
Sold. Thank you,sir!
@daboyz Dave, the speaker arrived today safe and sound, packaged to survive a nuclear first strike! It also must be lined with lead, I ain't going where I thought it would. I am going to need a stronger shelf. To look at it I wouldn't think it was ever taken of its original box.
Bruce -
Glad to hear! I should have said that the thing is a freaking monster but I was afraid no one would buy it.
It's a really nice piece. I hope it works out .
