Stereo pre amp for 2 channel
LORDROOTMAN
LORDROOTMAN Posts: 3
edited February 2019 in 2 Channel Audio
I have McIntosh MC601 mono blocks
Looking for stereo preamplifier to match for two channels music
I want something with HT Bypass
Like C52 ,anthem STR any suggestions
I will upgrade my set up in future
So far I’m using all klipsch 7.1
RF7II,RC64II RS62II 2 SW-115 subs klipsch
    VR3 Posts: 29,700
    For the price try ci audio plc
    Might be surprised
  • codycatalist
    codycatalist Posts: 2,661
    Wrong thread! I do appreciate the like though. I can't give much advice as my amps are not even close to the same league thus my preamp probably won't cut it. I do like my Denon PRA-1200 though.
    mhardy6647 Posts: 35,522
    Note decay is only a really problem with sugary, saccharine songs* -- or the Beatles' Savoy Truffle.
    https://youtu.be/z9EaBjFvQpc
    _______________
    * which are, ironically, rampant right around this time of year :#
    https://youtu.be/wh15LOppcWQ
    If I EVER get to the point that I start listening for how long a note lasts or "decays" I will know I have made it.
    When you really have made it, you'll be listening to the joy and emotion of music, and not just sounds.
  • motorstereo
    motorstereo Posts: 2,412
    MC601's paired up with Klipsch speakers!!!! I'm thinking you never get to see the needles move.
    and he won't be able to hear it any more after they do. :/
  • verb
    verb Posts: 10,176
    I've run VTL, Cary, and EAR tube preamps to my MC300. The tube pre/SS power amp combo, IMO, is fabulous! :smile:
    BTW welcome to the forum!
  • monepolk
    monepolk Posts: 1,154
    Don't have a suggestion, but welcome to the forum.
