Can you help me
My soundbar works great, woofer does not. Solid green light tells me they are connected but no woofer sound.
Answers
Hello,
Can you tell me which soundbar you have? -
Polk surroundbar 3000
Thanks, I'll try and find out something for you.
Soundbar works great, woofer is supposed to connect wireless. Solid green light means it's connected so I'm assuming they are in sync. No sound from sub, polks remote doesn't work for sub but works sound bar and for all other functions. They are on the same channel, I've tried switching channels, used all 3 sources,(tv,cell aux, microphone) no sub, took speaker and control panel out to inspect, and nothing looks disconnected or disarray, put right back together, still no sub, just sound bar
